Old 1st November 2010, 01:24 PM   #1
Veke76 is offline Veke76  Finland
Default TangBand W4-657SC Project
I bought recently TangBand W4-657SC drivers and 3 pcs of 1000x200x18mm glued pine board and I'm starting to build my first DIY speakers. I was inspired to start this project after listening fullrange Gradient Preludes and my PC got Logitech Z-2200 speakers which are TangBand W3-series. Those sound great to me so why not start your own speaker project.
The speakers are planned to be used as a second stereo set in kitchen/terrace/sauna/bedroom. Music source is iPod touch and amplifier is Harman/Kardon HK 3370.
The box itself is planned to be sized (WxHxD) outside 150x240x236mm and inside 114x204x200mm. After sawing there should be 240x150mm 4pcs, 240x200mm 4pcs and 114x200mm 4pcs. Volume of box is planned 4,65 Litre (acoustic volume 4 Litre). The box will be bass reflex tuned to 70 Hz and will have 45mm reflex port at length of 200mm.
I have used WinISD Pro to verify my plans. Couple of points which i found out is that:
1. Low frequency extension will be -3dB @ 81Hz and -6dB @ 67Hz
2. Max listening power will be 15W which will produce 101dB@1 meter and 92dB@3 meter. The cone excursion will be out of limits if more power is used.
3. Frequencies below 60 Hz should be filtered out. So I planned to use a high pass filter.
Old 1st November 2010, 02:39 PM   #2
The plans for high pass filter is to use 3 or 4 pcs of Intertechnik Audyn-Cap ELKO glatt bipolar 100 MF/35 VAC 5%. 300MF or 400MF connected in series to plus in the speaker.
Filters will be 300MF(-3dB@66Hz) or 400MF(-3dB@50Hz) and 6dB per octave.
The low frequency extension of the speakers will be affected by the filters, but because of impedance rising to max 60 ohms it won't be so bad.
What troubles me is that capacitors are rated only 35 VAC. In theory short term voltage could rise over that when impedance is 60 ohms. I could have bought 400 VAC capacitors but the price would have been 6 times more!
Old 1st November 2010, 03:40 PM   #3
Godzilla's Avatar
>>> The box will be bass reflex tuned to 70 Hz...
That's probably just about right. I don't think you will need to use a hi pass filter because the speaker will drop off naturally. But if you need more volume i would recommend adding a powered subwoofer and (maybe) stuffing the port to make the speaker a sealed box. You can also run the speakers thru the powered sub which will 'filter out' the bass but i prefer to run them straight from the power amp because it sounds better to me. Also, you might want to consider a tweeter. I've added tweeters on the back so not to spoil the full range look.
TangBand W4-1320 4" Bamboo full range driver
My project uses the tb 4" bamboo driver but i would imagine there are similarities between these speakers especially regarding their bass tuning and limitations.
Old 1st November 2010, 04:14 PM   #4
Ok. One weekend wasn't enough to get the speakers finished. Status of the project is 75% ready.
Boxes are pretty much finished. Some sanding, stain&lacquer and installing components is needed.
Old 3rd November 2010, 03:09 PM   #5
You got me intrested in tweeters! Allthough the speaker is not finished I have made plans to add TangBand 28-847S at top of box. Here is the "plan B" crossover circuit for it. DIYAudioAndVideo.com has great tutorial about crossover designing. I'll probably get my speakers finished next weekend so after that I'll see if "plan B" is set to go.
C1 = 7.95 uF (2500 Hz highpass 1st Order Butterworth)
L1 = 0.51 mH (2500 Hz lowpass 1st Order Butterworth)
R1 = 1.65 Ohms (LPad 2 dB)
R2 = 30.9 Ohms (LPad 2 dB)
C2 = 400 uF (50 Hz highpass 1st Order Butterworth)
Old 9th November 2010, 09:55 AM   #6
Two weekends spent building the speakers. Well maybe next weekend those will be ready.
I found a second option for tweeter TB 25-1719S. Good response all the way to 30kHz! Example of the crossover components can be seen on Standbox BPA CerAl 4.1
Maybe it's better select proven build of components than start building the crossover by yourself. Especially getting the right specs for components can be tricky.
I'm not sure wheter to go with 2-way system or stick with FR. Maybe I'll figure it out after carefull listening sessions with speakers.
Old 12th November 2010, 03:53 PM   #7
Here is couple of pictures of my TangBand W4-657SC Project. It's now finished!
Old 12th November 2010, 05:24 PM   #8
Short listening test revealed that everything works ok and sound is ok. I couldn't hear any problems in upper range and lower range works ok. There is actual bass coming from the speakers. Subwoofer with these would be nice Couple of pics from my test session
Old 12th November 2010, 05:46 PM   #9
Godzilla's Avatar
Cute and cost effective. Thanks for sharing the pictures.Great job! Now, what will your next project be? You can't just stop at one...
Zilla
Old 12th November 2010, 05:50 PM   #10
chrisb is offline chrisb  Canada
Zilla
kinda like 'tater chips
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
W4-657sc Salas Full Range 11 9th April 2010 02:03 PM
TB W4-657SC paired with passive & tweeter? Mayuri Multi-Way 3 16th March 2010 08:10 AM
BIB with 2 tangband w4-657? Mayday Full Range 2 23rd April 2007 10:53 AM
For Sale: Full range speakes made with w4-657sc dvdvideo Swap Meet 3 30th April 2005 04:24 AM
What do you think about Tangband W4-657s? mokus Full Range 8 16th February 2005 08:26 PM
Page generated in 0.11751 seconds (88.25% PHP - 11.75% MySQL) with 11 queries
