Old 21st October 2010, 09:28 AM   #1
gooki is offline gooki  New Zealand
Default 3 to 4 inch full range recommendation
Hey, does anyone, have some recommendations on a 3 or 4 inch driver that would fulfill the following criteria.
- Smooth response on axis and to 30 degrees off axis (100% fat not necessary as I have about 3 bands of peq)
- Work well in 2.5 liters sealed.
- Potential for extended bass response with EQ, -12db at 30hz or better would be great, but I understand this may be asking to much.
- 4 or 8ohm
I have a few ideas, but am not sure if i'd be expecting to much from them. So if any particular driver jumps out to you as a must try, let me know.
Thanks.
Old 21st October 2010, 09:50 AM   #2
el`Ol is offline el`Ol  Germany
This comes close:
Audience A3 3" Full Range Driver | Parts-Express.com
I think you understand that these are no requirements for a budget driver.
Old 21st October 2010, 09:56 AM   #3
picowallspeaker's Avatar
This comes close:
It is 16 Ohm , so to get the desired 8 Ohm you should use two
Old 21st October 2010, 10:02 AM   #4
audi0 is offline audi0  Australia
audi0's Avatar
Tangbands? Tangband Speakers
Old 21st October 2010, 10:09 AM   #5
Yeah a couple of Tangbands are high on my list of drivers to try.
The Audience looks nice, I can live with 16 ohm and the price if I have to, but would prefer a circular basket.
Old 21st October 2010, 11:02 AM   #6
The Mark Audio Alpair 5 was used like that I think - small sealed box, digital EQ to give output of -0dB at down to 30Hz: Alpair 5 Review by LeanAudio of Japan | Markaudio ... I'm pretty confident the Alpair 6 could perform here too.
I'd have a look at the Omnes BB 3.01 too. This is basically an upscale 3" Tang-Band.
Old 21st October 2010, 11:58 AM   #7
ttan98 is offline ttan98  Australia
TRy this:
HiEND 4inch full range fullrange defy lowther &forster on eBay (end time 07-Nov-10 15:37:33 GMT)
I bought a pair have to admit they sound really good at about AUD$100/pair including shipping is a bargain. I am thinking of getting another pair.
I use it a sealed enclosure about 5 litre, x-over around 70-80 Hz to a sub woofer. The combo sounds very open for such a small enclosure. I want to use them as my laptop speakers, however they sound so good that I use them in the lounge room for long term testing, you see I have other speakers as well.
Old 22nd October 2010, 02:52 AM   #8
Originally Posted by el`Ol View Post
This comes close:
Heckuva driver, no question, but for about the same cash outlay it would take to do two of these a side, I went for 80+ PE 289-106 3.5" drivers which I am using to build a 9.1 - 9.4 channel HT surround sound system (prototype photos in the picture forum). I even found an easy way to get the Fs down to the 60hz range on these which is about the lowest I've seen for any speaker under 4" diameter.
Old 22nd October 2010, 04:46 AM   #9
Thanks for the rest of the suggestions.
12 inch full range enzedone Full Range 58 11th April 2012 08:02 PM
Full range recommendation w/ special restrictions... vaughn Full Range 7 5th April 2012 06:17 PM
my 14 inch full range speaker! NVMDSTEvil Vendor's Bazaar 28 1st October 2011 01:42 AM
Need cheap full range 5 inch Josh Lasserre Full Range 24 8th July 2011 05:55 AM
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 01:30 PM
Page generated in 0.10063 seconds (79.16% PHP - 20.84% MySQL) with 10 queries
