Old 14th October 2010, 10:20 PM   #1
Default Calculate PLLXO notch from speaker-level values?
I'm fooling around with an old Cyburgs Needle build that has W3-871S drivers. I have Omnes Audio BB 3.01 drivers, which look to be a swap-in physically. I'd like to try them ...
The notch filter is different for the Omnes. HenkJan posted his values of 0.33mH / 1.8R / 22µF in the Cyburgs Needle thread. The Omnes driver's electrical impedance is 5 Ohm. I don't have these values on hand, and I want to see if there's a way to do this passive with resistors/caps I already have.
Can I convert this notch filter into a line-level notch with a combination of first-order highpass and lowpass PLL RC filters? The amp input impedance is 22K.
What's the process of doing a conversion/recalculation like this?
Old 17th October 2010, 08:50 PM   #2
Attached is an ugly graph of what the notch does. Is it possible to do such a curve with a PLLXO?
(The curve is centered on 1940Hz, with a 2.67 dB attenuation at that point.)
File Type: png Screen shot 2010-10-17 at 8.48.21 PM.png (33.4 KB, 47 views)
How do we calculate the values of the boot strap resistors ? tessier Solid State 4 8th October 2010 11:27 AM
help with passive line level crossover PLLXO for 33K impedance amps Daveis Analog Line Level 1 14th December 2008 08:12 PM
Calculate PLLXO audiobomber Multi-Way 5 22nd August 2007 05:34 PM
passive line level Crossovers pllxo Preacher Multi-Way 4 11th October 2006 08:57 AM
Need Help to calculate Thiele/Small values andrew01 Multi-Way 9 7th April 2006 10:42 AM
Page generated in 0.06813 seconds (67.68% PHP - 32.32% MySQL) with 11 queries
