Hi All. I am attempting to put of OB comp circuit into my OBs and can't figure out what the triangle is in the Edge program schematic. Here is a screen shot.
Also, if you know the Edge program, how do I determine the R1 ohms? I read through the manual on the website but it did not address it. |
#2 |
frugal-phile(tm)
The triangle is most often an opamp.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Hi Dave, there is no mention of an opamp anywhere in the lit, but that was my thought as well.
#4 |
Just found out that the triangle is my amp, so the circuit starts at the input of my amp and goes to the output.
#5 |
frugal-phile(tm)
That assumes a lot about your amp. You'd be putting an additional feedback loop around the amp with no concern for its input and output impedance. I wouldn't do that. I'd make an active filter using an opamp (or substitute).
dave
#6 |
Just got an email back from Svente, the designer of the EDGE program. He wrote:
Ah, ok. Well, this little circuit goes between the preamp and the power amp, it is typically not part of the power amp (even if it could be). One should also keep in mind that the compensation circuit only takes care of the baffle effects, and that it is common to use drivers with a high Qts for compensation. The driver properties are not at all included in the Edge simulations. /Svante Dave you were right about the OpAmp, I just was not use to seeing it in a speaker circuit. |
| hi comp amps | chuchu31642 | Car Audio | 4 | 22nd June 2010 10:41 PM |
| threads become "read" before I have a chance to read them. | y8s | Forum Problems | 2 | 10th February 2008 10:57 AM |
| MF12 Comp PCB's | Cambe | Solid State | 1 | 26th May 2006 05:30 PM |
| I missed the Logo comp | squalor | Everything Else | 2 | 13th August 2005 02:38 AM |
| Looking for Carbom Comp resistors | Wardsweb | Parts | 7 | 14th February 2003 06:44 PM |
| Page generated in 0.08299 seconds (72.92% PHP - 27.08% MySQL) with 11 queries |
