Hi to all:
I would like to experiment with an OB using one set of these drivers and was wondering if it would be worthwhile experimenting w/ the Betsy first and then going on w /the Visatons.. or just go ahead and go w/ the Visatons. What would users w/ experience w/ both drivers recommend. Thanks.
I think rjbond3rd had a thread where he compared the two. I, of course, thought it was a favorable comparison! You might dig it up or shoot him a PM for an opinion less biased than my own.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Paul
Hi guys,
You are right, Paul. Betsy came out really well. The Betsy is easy to work with, and is vastly less expensive. There was no fussing, it worked out of the box for me on the large Dark Star OB that is on your site. I was so happy.
And then I had to try the Visatons. It's much harder to work with! It demands patience and perfectionism. It's a sort of Mt. Everest thing. It is much more expensive, really high-end construction but I spent months on a quest trying to really tame it. Then you may end up with at least a notch filter, maybe digital EQ, phase plugs etc.
I will never forget that night when the Betsy's were installed. It was amazing. It was the first time I heard OB in my living room and it was beautiful. Maybe I should have stopped there. The B200 turned into a quest lasting many months and frankly, it exhausted me but others have enjoyed the challenge.
Bottom line (in my opinion):
Betsy: plug-n-play and within its design limits, it just works.
B200: more raw potential, it requires tremendous patience and extensive experimentation. It kinda drove me nuts.
Thread:
http://www.diyaudio.com/forums/full-range/153951-ob-dark-star-shootout-betsy-vs-b200.html
Thread:
1" voice coil, Kapton former. I'm sure I have some off axis charts somewhere. I'll look when I have the chance.
Paul
Paul
>>> speaking of off axis
........ or just make something unique?
Zilla
if lucky
well, I did consider very carefully how to avoid compromises, and still kept simplest possible, and small
but it seems like the close coupling to the floor has some advantage
well, at least its cheap and easy to try it
very low ""show" factor
but maybe high WAF factor
might even be "multi place able"
Now I think about it again, maybe it could be mounted on a wall also
might be used in low power surround, etc
whatever, mine will be 2way, with 2" alu cone tweeter
but thats a different story
I try ed the betsy and the visaton next each other and they both have there strong points
Betsy very clean and good highs
Visaton have a more warm sound
the best sound was to let them play together
so I'm going to build them together in one OB and see what happens
go luppe go!
- Full Range
- Visaton B200 Vs. Wild Burro Betsy...
