Martello enclosure for FR88EX
Old 17th February 2011, 09:29 PM   #81
BoilermakerFan is offline BoilermakerFan  United States
BoilermakerFan's Avatar
Al, if you need felt for critical locations, LMK the sizes and I should be able hook you up. I'll email you the details of this stuff.
Old 17th February 2011, 09:58 PM   #82
Uncle Meat is offline Uncle Meat  Germany
Uncle Meat's Avatar
The inductor is size of a 3W resistor?? Seems you have an MKP "overkill" cap ( not bad, btw) , plus a cheapo chinese crap inductor, ...
NONO
Old 17th February 2011, 10:25 PM   #83
pabbi1 is offline pabbi1  United States
Brian, I actully spent $1.50 at JoAnn for the felt, so I'm good there... and, busted on the inductors, since it was from my local surplus guy. Recommendations on GOOD inductors, since I didn't see any on eBay... this is just an area out of my league.
So, felt and poly-fil, felt without poly-fil, poly-fil without felt?
Old 17th February 2011, 10:54 PM   #84
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by pabbi1 View Post
If I use poly-fil, would I still need felt, or, would I only need felt in certain places?
I believe the felt is a good idea. I've built speakers before with mostly poly-fil and this time I used only felt and I thought the only felt was much better at controlling reflections off the back wall of the cabinet.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th February 2011, 11:35 PM   #85
OK, pics... the cocobolo isn't nearly as dark in person. And, my filter parts...
Old 18th February 2011, 04:57 AM   #86
Finished - would still like input on poly-fil:
Old 18th February 2011, 05:06 AM   #87
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
It is essentially a BR. You line the walls of a BR you do not volume fill it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st February 2011, 07:13 PM   #88
With about 20 hours on them, the imaginig is pretty good (placement is critical), but they are still just a bit 'honky' on hard rock, really sweet on Alison Krause, and all over the mid range (guitar, piano, banjo, vocals). Mayhaps a bit tinny on top. Some of this may be the tube amp, or the cheap DVD source (may have to try this with the Ayon CD-1), but I'm pretty sure the speakers need some adjustment.
Afraid the felt is insufficient - can some Poly-fil help? Will the filter help? Really close, but tweaking is what DIY is all about.
Old 21st February 2011, 08:17 PM   #89
Bigun's Avatar
Hard rock and 2" drivers are a challenge, I have not found them large enough for this kind of music. The top end has been good in my case, based on use of SET with Magnum Dynalab FM tuner and a good channel. Have had good results with Dual turntable although cartridge was a bit too rolled-off on the top end compared with the tuner for my taste. Have had mixed results with CD player, seems the usual problem that most recordings are poor unless I am very selective.
Old 21st February 2011, 09:44 PM   #90
frugal-phile(tm)
planet10's Avatar
The Twin pair in my uFonken^2 don't do so bad.
dave
Martello enclosure for FR88EXHide this!Advertise here!
The Fountek Five for FR88ex planet10 Full Range 55 5th January 2018 09:00 PM
MARTELLO-2, a mini-tower from a single 2' x 4' Bigun Full Range 60 3rd September 2016 07:35 PM
Martello Fr88ex awqawq Full Range 6 27th August 2012 12:24 AM
Need an amp for Fr88ex awqawq Chip Amps 0 28th July 2012 12:04 AM
FR88EX Fountek Vendor's Bazaar 10 3rd April 2012 11:21 PM
