Martello enclosure for FR88EX - Page 5 - diyAudio
Old 3rd December 2010, 05:29 PM   #41
frugal-phile(tm)
planet10's Avatar
Originally Posted by Oberlix View Post
This will be interesting to see, there was a company a couple of years ago that did a set of cardboard speakers for computer enthusiasts that folded up so they could be carried. Though i believe they were based on a planar design.
It was an NXT based design.
My 1st cardboard speaker boxes were for a set of Joran-Watts over 30 years ago.
My last set of cardboard speakers, convinced me thou that Chris would have spent less time slapping together a plywood set (a set of Metronomes for a set of unobtainium TB 3").
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd December 2010, 10:24 PM   #42
Oberlix is offline Oberlix  United Kingdom
Planet 10 I stand corrected
Old 4th December 2010, 09:02 PM   #43
ChestofFur's Avatar
Default 1/2'' cardboard
Two pieces of cardboard glued together is about 1/2''
per the original design.
Cutting carboard is indeed time consuming. And now I've
promised to build my little cousin a cardboard car.
Sorry for the blurry picture.
Old 4th December 2010, 10:14 PM   #44
Bigun is offline Bigun  Canada
Bigun's Avatar
Maybe this thing can work - cardboard doesn't resonate much. Plan to add a lot of stiffening if you can. Glue some strips of cardboard edge on to some of the internal faces to provide added stiffness, like beams underneath a wooden floor.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th December 2010, 08:50 PM   #45
ChestofFur's Avatar
Default Pictures
Ok, first off, making these has been a lot of fun but very time consuming. Once everything is assembled, the cardboard feels pretty darn rigid.
A friend and I did the first listening test yesterday evening - no lining yet on the inside and without the divider thingy that goes behind the driver. In my large living room, placed far away from the boundries they sounded pretty amazing on all types of music. My friend isn't one to spare my feelings and even he really enjoyed them. Of course, they couldn't play to loud but for what they are, there were no glaring issues.
Next we moved them to a small room and there they sounded pretty horrible. As a complete non-expert, the best I can say is that they hurt our ears and sounded veiled maybe.
Back to the living room and they sounded great again. Wish I had a sub to try them out with.
Making these I figured these would work well in a small room, on a desk as computer speakers, etc. I was surprised at how well they worked in a big room.
Well, today I finished lining them with some foam used for preventing drafts under doors. The results aren't good. One benefit seems to be they are playing much louder, at least the upper frequencies definitely are. The problem is they hurt to listen to. They are really stabbing at my ears. Also the balance seems to be gone in the frequencies. Well, that's the best I can describe it.
So, where to from here? I'll start taking off some lining a little at a time. Problem is I'm not sure from where to start. Should I start from the top above the divider thingy or from the bottom, back, front?
Still considiring a notch or tweeter. If I can find the parts for a notch, I might try that and I might test with a tweeter on top. First I have to solve the lining problem. I was pretty disapointed when the sound went from good to bad.
Old 7th December 2010, 09:35 PM   #46
Uncle Meat's Avatar
Hmm, I guess this foam is "closed-cell" type. Can you breathe through? No? Then it only reduces the Box volume.. And, no damping of mid frequencies. Makes things worse...
Old 7th December 2010, 09:46 PM   #47
ChestofFur's Avatar
Just gave it a try. I'm able to breathe through it. Maybe I used too much.
Old 7th December 2010, 10:09 PM   #48
Bigun's Avatar
hmmm. I can't see the enclosure causing a harsh unbearable sound unless there are copious reflections from directly behind the driver (I put felt on all surfaces) or the bass has disappeared and you only have hf left to listen to (which might happen if the enclosure is flexing like a balloon or is poorly sealed except for the port).
Drivers can take some time to break-in. The Fountek drivers didn't change as drastically as the Fostex drivers I had before (which went from truly awful to OK in about 2 hours and to very good after 100 hours) but it does take a hours of play to bed them in. I'm not sure why, but playing them exercises all the materials and moving parts.
Another thing, I use a tube amp and it appears to be a better match to FR drivers than any of my SS amps.
Old 8th December 2010, 12:24 AM   #49
ChestofFur's Avatar
I took the lining out of the top chamber and the sound improved significantly. Next I removed the lining off the front baffle and it's even better. The harshness has almost disapeared. Might actually be fine at this point, but it sounds like something is slightly off. Still a tiny bit of harshness there. I'll listen again tomorrow and maybe try taking out all the foam and replacing it with felt.
Old 10th December 2010, 05:19 PM   #50
ChestofFur's Avatar
Default Unpainted
After a lot of playing around with the lining, I've glued the 'cabinet' shut. Near field and placed close together beside my computer these sound almost perfect.
I'm really enjoying them. Using the eq on foobar I can adjust frequencies if I need to and lower bass output so they don't work too hard. Really though, they sound great. Again, wish I could listen to them with a sub and a proper receiver.
BTW, one of the channels on my t-amp died out during all this
Next, I have to figure out how to paint them or cover them.
MARTELLO-2, a mini-tower from a single 2' x 4' Bigun Full Range 60 3rd September 2016 06:35 PM
The Fountek Five for FR88ex planet10 Full Range 52 12th October 2014 09:32 PM
Martello Fr88ex awqawq Full Range 6 26th August 2012 11:24 PM
Need an amp for Fr88ex awqawq Chip Amps 0 27th July 2012 11:04 PM
FR88EX Fountek Vendor's Bazaar 10 3rd April 2012 10:21 PM
Copyright ©1999-2017 diyAudio
