Martello enclosure for FR88EX - Page 12 - diyAudio
Old 29th August 2011, 12:59 AM   #111
Bigun is offline Bigun  Canada
Bigun's Avatar
I was contacted by a person from Indonesia who was not able to obtain this driver, but did have it's brother, the FR89.
These are my thoughts on the suitability of this driver for the Martello enclosure:
First off, I've not tried it of course so I took a quick look at the datasheets for both drivers.
The frequency response curves of both drivers look very similar, no problem there.
Next I took a look at the specifications
fs 95Hz vs 97Hz - close enough so no problem there
VAS 1.269L vs 1.111L - here the's a bit of a difference. I don't think it's critical, the FR89 has a smaller VAS but the driver also has a larger magnet and eats into the enclosure volume slightly
Qts 0.472 vs 0.468 - close enough so no problem there
Lastly I took a look at the physical size:
magnet depth: 38mm vs (46.9mm-4.3mm=) 43.6mm - a noticeable difference, but all this means is that the holey brace behind the driver will need to be shorter to accommodate the deeper driver, just cut it size as you build
hole cut out diameter: 73mm vs 73mm - same, no problem
Overall I'd say yes, that this driver would be suitable. It won't sound exactly the same though. Of course, it might sound better :-)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 3rd November 2011, 11:33 PM   #112
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
What would be best if building these?
22mm particle board or 12mm particle board? I have some scrap pieces lying around at home and the drives are quite cheap. A pair of martellos would make a nice gift or just a desktop speaker.
Old 4th November 2011, 02:26 AM   #113
Bigun's Avatar
I would suggest the 12mm because it will be a challenge to scale the design for the thicker board. I'm not much of an expert on particle board - don't know how suitable it is for this project. But it's DIY - give it a go and let us know if you like the sound !
Old 4th November 2011, 02:30 AM   #114
malibujeff's Avatar
Go with the 12mm. For a box this small, it should be enough. If course, particle board would not be my first or second choice.
Old 4th November 2011, 05:01 AM   #115
frugal-phile(tm)
planet10's Avatar
Better than MDF, not as good as ply.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th November 2011, 09:59 AM   #116
Rullknufs's Avatar
Okay, as i thought the 12mm would be better. I still have some left from my Mar-Kel70 build. I found the FR88EX in sweden for ~$45/each which seems to be a quite ok price.
Old 4th November 2011, 10:31 AM   #117
frugal-phile(tm)
planet10's Avatar
That is not bad. They are up around $50 now after Neo inflation. I paid a little over half that for mine.
dave
Old 4th November 2011, 10:32 AM   #118
Rullknufs's Avatar
Yes i was actually a little "shocked" about the good price. Only ~$5 higher than at madisound, and that's across the ocean where things usually are a lot cheaper than here.
Old 4th November 2011, 05:18 PM   #119
Bigun's Avatar
Wow, I didn't know the price was up that much, makes my little speakers more valuable
Old 4th November 2011, 06:16 PM   #120
malibujeff's Avatar
I paid $22.75 each back in February. Now they are listed for $39.90. That is a huge increase. I probably would not have built my Martello's if the drivers had cost that much. Glad I got them when I did.
MARTELLO-2, a mini-tower from a single 2' x 4' Bigun Full Range 60 3rd September 2016 06:35 PM
The Fountek Five for FR88ex planet10 Full Range 52 12th October 2014 09:32 PM
Martello Fr88ex awqawq Full Range 6 26th August 2012 11:24 PM
Need an amp for Fr88ex awqawq Chip Amps 0 27th July 2012 11:04 PM
FR88EX Fountek Vendor's Bazaar 10 3rd April 2012 10:21 PM
Copyright 1999-2017 diyAudio
