To make a story short, Ive read here most of the threads about Philips 9710MC, Lowther, Pionner, Fostex, Aer, Fertin, Feastrex, Tandbang etc.(not heard them all for shure!)
Pricewise (satisfaction per dollar wich one gives you the best satisfaction). I remember the Philips 9710 (in the 1975 glory years )and they where cheap for satisfaction/excitement compared to other expensive multiway speakers.What if you had a 5.1 surround system with full rangers (8") with a sub of course. It could be quite cheap(depending if you don't buy Aer, Lowther or feastrex...) and it would have the benefit of a seamless integration for the center channel. Seas exotic(SEAS X1-08 EXOTIC F8) is expensive but how does it compares to other drivers about -50%/+50% of it's price range? Just thinking about it |
#2 |
Hi, I have compared the F8 to the Fostex FE108E Sigma (not exactly a match pricewise though) and the Quad ESL63. So, all are fullrangers but fall out of your +/-50% price range limit.
Anyway I felt the F8 "clearer" than the FE108, and less stressful to listen to. It has a lot of low-level detail and is also more balanced. Compared to the ESL63, it is a little bit more "in your face" (or the Quads too laid back), I have a hard time deciding which one I like more. The F8 tends to lose out on complex, large settings e.g. symphony orchestras - with voices, strings, folk music with not so much happening at the same time it is just wonderful. So, not sure this makes it an ideal choice for a surround system. If all you do is watch movies then the FE108 might be for you, its much more compact ( I use it in a 8l vented enclosure (yes, not a horn)) and it does just fine. Badly needs a subwoofer though hope that helps |
#3 |
I do believe we've just discovered why you find the Seas less 'clearer' and 'less stressful to listen to than the 108. With little in the way of linear excursion, in an 8 litre vented box the VC on the Sigma must be spending more time out of the gap than in it. Fostex drivers overload reasonably gracefully, but there are limits...
Comparing between drivers is always a crapshoot; unless you're comparing between equivalent units (i.e. same size, & designed for the same purpose) it's not going to tell you a great deal other than that they're different. The Exotic's supposed to be a good unit for what it is. What will give the best results depends on what it is you want to do with said drivers, the rest of your system / room, to say nothing of personal taste. |
#4 |
Hello,
i compair in different enclosures Lowther, Fostex, Sica, Nirvana, Visaton with measurements, the Seas is a good driver but for a 5.1 a bit expensive, i prefer for classic the B200 Visaton, no wizzer! or the AN super 8" in my Trumpet or Schalmei Sat with 2 or 4 Alphorn sub, see my HP.
http://www.hm-moreart.de |
#5 |
Beautiful speakers cabinets hm!
I know that the Fostex line is quite used here for dy projects. True that when those speakers used in rear loaded enclosures, they can be big and this can be a lot of woodwork for a 5.1 system. Imagine the cc in a dual rear loaded (with the tranducer at the center of the cabinet). At least you have a better cc integration than any other systems tone wise and dispersion wise |
#6 |
Hi Scottmoose,
agree. Apologize I missed to mention a few more things, the listening levels were not VERY loud, and I was using the FE108 with a subwoofer (so not asking a lot of bass). The F8 was used without a subwoofer, and on an open baffle. I guess that "distorts" the test setup quite a bit, since the conditions are so different for the different drivers. |
#7 |
Agree. >>> Pricewise (satisfaction per dollar wich one gives you the best satisfaction). The ones that you can afford that sound best to you. I have thought about the Seas, Lowther and Feastrex but having several full range drivers that vary in price i find little in the way of enjoyment vs price. A VW GTI is an enjoyable car to drive but it's cheap compared to a Porsche... and with the Porsche i have to worry about dings. I'd hate to own the Seas and be unhappy with it. |
#8 |
great analogy godzilla!
and i also agree about the price vs enjoyment ratio on most "full range" drivers. to my experience, the only way to get "full range," much less decent dynamics, is to use multiple drivers... |
#9 |
Hello, has anyone compared the X1-08 EXOTIC F8 to the cheaper FA22RCZ ? On paper they look the same.
thanks |
#10 |
I think that's a fair question and would make a good comparison. Having a few Fostex drivers i can say that their higher end Sigma line tends to sound a bit better than their lower end line in the way of smoothness and in their ability to handle more power gracefully. Otherwise, they are similar. As for comparing Feastrex, Lowther, etc... to get the most from them we can all see that many here go to a lot of trouble to make these expensive drivers sound their best. Very large baffles and complicated back horns are the norm. When buying them we need to ask if we have the time, patience and space to own these lovely, refined drivers. The reward of dialing them in just right is probably worth it if one is willing to try. Zilla |
| Sealed enclosure for SEAS Exotic | johnsonad | Full Range | 58 | 9th October 2011 08:14 PM |
| Seas Exotic Pricing | Arc | Full Range | 68 | 23rd November 2010 10:05 PM |
| New Seas Exotic drivers | bambadoo | Multi-Way | 21 | 28th September 2010 08:50 PM |
| Seas Exotic X1-04 F8 | dcathro | Swap Meet | 11 | 10th April 2010 10:08 PM |
| What happenned to SEAS Exotic? | anubisgrau | Full Range | 6 | 17th June 2008 09:49 AM |
| Page generated in 0.11714 seconds (84.80% PHP - 15.20% MySQL) with 11 queries |
