Old 29th September 2010, 08:22 PM   #1
vladn is online now vladn  United States
Default rear ported desktop box for fe126en ?
I'd like to build compact desktop/computer speakers using fe126en driver. It will be powered by a tiny tube amp (1-2W class A triode PP) hence the choice of the driver.
My preferences are:
- cabinet width as narrow as practically possible;
- driver axis height about 1ft from the table surface;
- rear firing port/horn;
- reasonably easy construction.
Currently I am thinking along the lines of folded voigt pipe with rear exit port. Is there any tuned/tested design with similar parameters that I can reuse ?
Old 29th September 2010, 08:35 PM   #2
renfrow is offline renfrow  United States
renfrow's Avatar
I've built several versions of this Folded Monopole design that I've been really happy with. In that thread there are several other single speaker variations that you might like.
Tom.
Now, we can do this the hard way, or... well, actually there's just the hard way.
-- Buffy Summers (Buffy the Vampire Slayer)
Old 29th September 2010, 08:46 PM   #3
chris661's Avatar
I built a later version of those
diyAudio Full Range Reference Project
They're awesome. Enough bass when near a wall, though too close and it loses definition...
I'm fairly sure you could move the opening to the back of the cabinet, though I'd get that confirmed before going off something I've said.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 29th September 2010, 10:20 PM   #4
I built a pair of the folded fe126. Not finished with them yet, need some stuffing and finish. Here is a pic. They sound nice except for a bit boomy on the bottom end, which I think stuffing will take care of.
Old 1st October 2010, 08:19 PM   #5
Thanks guys. The last two suggestions are a bit wide for my needs, I'd much prefer narrow/deep configuration. Post #539 by planet10 from the folded monopole thread is interesting indeed but I am not sure how well it will translate to fe126.
Old 2nd October 2010, 12:17 AM   #6
I just realized you are using the fe126en, which is different than either driver, but closer to the fe126e than the fe127e. So...
The one is post 539 is only about 0.5" narrower than the one in post 797 linked by chris661 that I built, if built with 5/8" ply as suggested. The fe127 cab is about 7 1/4" and the fe126 cab is 7 3/4". The one linked by chris661 is designed for the fe126, which is closer to the driver you have. Also, fyi, i have since posting stuffed the cabinets with acoustuff and it made a huge difference in the boomyness and cleaned up the midrange nicely. I had originally bought the fe126 for use in a horn, then decided I wanted them on the desk and these were the only small cabs I found that were designed for them. So, you will probably have better chance with the ones for the fe126e, but you may want to wait until someone designs specifically for the fe126en. Hope this helps.
Chris
Old 2nd October 2010, 03:23 AM   #7
frugal-phile(tm)
planet10's Avatar
For most practical purposes, from data collected to date, one can consider FE126e=FE126En. I'll get more data when the 20 En in process get to the bench.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd October 2010, 03:26 AM   #8
frugal-phile(tm)
planet10's Avatar
It is not suitable for FE126e or FE126En.
This driver wants a horn. The little FE126 box in the diy FR ref thread can be considered a mass-loaded tapped conical horn.
dave
Old 2nd October 2010, 12:15 PM   #9
chris661's Avatar
A suggestion... What're the chances of being able to mount the driver on the side panel of that cabinet? It wouldn't move the driver a huge amount, though I suspect the earlier baffle step could be a problem.
Chris - sounds like I need to try stuffing mine. My ears aren't perfect (previous best build involved cheap Visaton gear), so it sounds like there's more to be eeked out. Thanks.
Chris
Old 2nd October 2010, 07:45 PM   #10
Has anyone attempted building a true open mouth horn with compact (desktop) dimensions ?
Question on Adding Batting to Rear of Ported Cabinet nkx1 Multi-Way 4 14th February 2010 01:13 PM
Has anyone rear ported the GM MLTL 48 ? batdan Full Range 3 15th December 2009 06:00 PM
low frequency room response - front vs. rear ported JLC7 Multi-Way 0 3rd May 2009 02:04 AM
making a ported box.. 1needforspeed Car Audio 1 8th April 2005 04:44 PM
Woofer Towers, front-ported or rear-ported? Goldenboy Multi-Way 6 15th June 2004 06:44 PM
Page generated in 0.12299 seconds (81.65% PHP - 18.35% MySQL) with 11 queries
