Hopefully its not too broad a question:
What full ranger, with capability on peaks (only when occasionally cranked up) of 100 - 105 dB from 4 metres, if used with a pair of subs crossed at up to 150 Hz would have the least fatiguing but most “lifelike” sound? Im happy to fix a rising response and or peaks, in the active crossover to the subs For less beaming, preferably up to say 6.5 inch. Either - a stock driver - EnABLed I’ve thought of the FE126eN; FE166 Something from Mark Audio? If I went for 8” for higher sensitivity (maybe with some super tweeter I have, coming in c 5 kHz), how would the B200 compare? Or the L Cao 8 inch L.Cao full range speaker 8 inches pair (looks similar to Diatone P610) I dont know there are comfortable power handling - Again if crossed to subs at say 150 Hz, what SPL might the JX 92S or FR125S produce? For use with an OTL amp that measures close to 50 w into 8 ohms, 40 w into 4 ohms. At this stage, budget open Thanks |
#2 |
Hello,
for 100-105 dB i would try something like my HORN-Sat, with FE206, AN super 8", Sica 8" 1100, B 200
http://www.hm-moreart.de |
#3 |
Thanks, I imagine that would be *Very lifelike
though I just want a simple box having said that, the fostex 208 could be a good option I realize I need at least 94 db sensitivity, so that reduces the options that I'm aware of to the 208, 166; the B200 or the new driver I linked to for non horn loading, the B200 might be best?? |
#4 |
Hello,
the B200 would get only 90 dB 1W1m and you need to drop down all about 1kHz, than look my TRUMPET very easy built sat horn, look the measurements on my HP you will get 96-98 dB above 130 Hz and no crossover! ![]()
#5 |
They really do look superb, but if I do other than a box, it'll be open baffle
Are you sure the B200 is only 90 db? I must check the specs |
#6 |
#7 |
Yes, it only gets above 90 db, above c 800 hz
maybe an 8" phy or supravox or a coax. I recall PHL make a high efficency coax (the 1660?) but I'm a bit doubtful on coaxes |
#8 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
dave
you know these kinds of drivers If the sensitivity requirement is eased to include drivers with B200 levels of sensitivity above say 200 Hz, what driver(s) would you suggest? I can access a pair of "nos" 12 inch Goodmans Axiom 201. c 96 - 97 dB (If you know them?), paired with a HE tweeter to deal with beaming, how might they fair, esp against the B200? |
#10 |
frugal-phile(tm)
I had one pair of 201s thru here. I quite liked them. Not much over 12k.
FE126En, FE207e, FE168eS, FE166eN from the Fostex catalog. 208eS if you can live with a tweeter Audio Nirvana Cast 8 -- no personal experience, but gets good press. The ANs i've heard have been dissapointing. Tangband W8-1808. I've had both the big TB thru here, i like this one better, but at the expensive end of value for the dollar. Efficiency down around the same as the B200. Lowther, Supravox if you have a big budget. And other stuff i haven't heard i'm sure. Me i'd be looking at Alpair12. Or if you aren't in a hurry, the pricing that is being tossed around for the Alpair10.2 is crazy cheap. About the same efficeincy as A12 and for about the same $$ you could have 4. I figure anything they lose at the loud end of the dynamic range scale will be more than made up by their superb downward dynamic range. dave
| Fostex full-ranger for in wall use :-) | sharpi31 | Full Range | 4 | 5th March 2008 10:46 AM |
| Full ranger and a woofer question | audiophile36 | Full Range | 25 | 25th February 2008 07:54 AM |
| Center Channel Full Ranger? | dvarner | Full Range | 12 | 25th October 2007 11:55 AM |
| not really a full ranger | Nanook | Full Range | 3 | 3rd April 2006 08:20 PM |
| Beyma 5MP60/N as a full ranger? | Elias | Full Range | 2 | 25th November 2004 11:37 AM |
| Page generated in 0.12021 seconds (80.10% PHP - 19.90% MySQL) with 11 queries |
