I have acquired some pretty nifty 8ohm, 6.5 inch drivers that I would like to put in a big box/pipe/horn of some sort. The are from some old Olson bookshelf speakers and were running in there crossed with a 2uf cap to a tweeter (which crosses at ~4-5K right?). The drivers have pretty respectable alnico magnets and reverse roll cloth surrounds -- kinda like an enlarged FE103A. I think I've osmosed that BIB is fairly forgiving and also noticed that the measurements are fairly close for all of the 6.5" fostex drivers. Could I just work up something from those numbers and expect reasonable results? Is there a better enclosure for drivers of unknown T/S measurements? Thanks, Michael |
#2 |
Hmm, well you could build a BiB for a known driver, and then substitute your mystery driver in. And if it didn't work out, you could get the known driver for that BiB. BiB's are forgiving and I have put the "wrong" driver into them and was happy at the time, but I wasn't extracting maximum performance either.
A device to measure the drivers (woofer tester) is about $100. But if that's un-doable, you could use test tones to find the Fs -- that would at least be a start. |
#3 |
Any idea what its Fs is? I have a design routine from before T/S that only uses Fs, Sd.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 |
Thanks for pointing me in a direction. A) I had thought of T/S as all or nothing but it is easy enough to determine Fs so I'll get to that in the next while. B) I was unaware of the woofer tester. I might get one of those as I've got some other speakers I'd like to learn more about as well. Also a good idea to just build for a different 6.5 so I could put that one in at some point.
-Michael |
#5 | |
http://www.lowellmfg.com/technical/a...e%20driver.pdf |
#6 |
hitsware, i'd slap that 8" driver onto an open baffle. Looks like the top end is very blendable with a tweeter if lacking sparkle. funny how ceiling speakers could be used as inexpensive ob speakers with good results.
i like rj's advice to build for something else and try what you have. This way if what you have doesn't sound good you have a fall back plan. |
#7 |
me too .... but outta curiousity ...... |
#8 |
Since I last opened this Excel SS, it got corrupted somehow, losing the basic drawing and scrambling up the calculation layout a bit, but the math is still correct.
Driver Diameter: 6.540 in Desired Fb: 88.00 Hz Sd: 33.593 in Best Mouth Area: 268.742 in2 Best Width: 16.393 in Best Depth: 17.268 in Voigt Horn height: 26.641 in port height: 2.049 in vent area: 268.742 in2 r-port: 9.249 in nominal Vb: 4.355 ft3 123.318 L L: 48.435 in At: 2.049 in Sm: 268.742 in2 X0: 0.4220 % 0.5780 % (corner) GM
#9 |
>Sd: 33.593 in
>Best Mouth Area: 268.742 in2 >Best Width: 16.393 in >Best Depth: 17.268 in Vb (length) same as Voigt ? |
#10 |
Vb = box volume. Total length L = 48.435". It's not clear without the sketch, but it's like a BIB in that it terminates to a point and is tuned to Fs rather than an octave lower, so folded is ~half this.
GM
| ml tqwt with unknown driver | stevodude | Full Range | 20 | 13th August 2008 05:34 AM |
| Driver Rms-value unknown, what to do? | mac-attack | Subwoofers | 9 | 7th January 2007 09:54 PM |
| Unknown fullrange driver | bigwill | Full Range | 3 | 15th February 2005 05:30 PM |
| Subwoofer design with unknown driver | miguel2 | Subwoofers | 8 | 11th February 2004 05:11 PM |
| Unknown driver help | postman | Multi-Way | 4 | 23rd September 2003 08:44 AM |
| Page generated in 0.10239 seconds (81.45% PHP - 18.55% MySQL) with 10 queries |
