HELP, I need a full ranger that I can hang on the wall
Old 25th September 2010, 05:23 PM   #1
rtenyes is offline rtenyes  United States
Default HELP, I need a full ranger that I can hang on the wall
Hello,
I'm looking for a full range project (4" driver?) that I can hang on the wall. I'll be adding a sub so I'm not so concerned about lower end. I'll be driving it w/an old B&O ss 55 watt receiver with my mac as the source (I'll be adding a dac because my sound card has taken a crap on me).
It's my office, so the front walls are about 8' away, sides are 5' and back wall is 6'. I want to hang them about 4.5' up. Measurements are from my sitting position.
I've built several sets of speakers and subs, but only 2 full range projects http://www.diyaudio.com/forums/full-...gers-done.html and a tang band 3" near field set of computer speakers. I really liked the way the fostex design sounded, but they needed to be away from the walls. The tang band speakers sounded good for what they were, but I want something that sounds better. I have absolutely no experience starting a project from scratch.
I'd like to keep the component cost to $300 (or less) not counting the enclosures. I'd love to try the fostex sigma, but...? Or if anyone has old drivers they'd like to get rid of I might be able to give them a good home.
The main goal is to get these things on the wall (and sound great), not in the wall or on stands in front of the wall. Any suggestions or projects would be appreciated.
Old 25th September 2010, 05:28 PM   #2
borispm is offline borispm  Hong Kong
borispm's Avatar
Send a message via MSN to borispm
I think you can try the Peerless Aluminum drivers, I wanna try them for a long time but I eventually ended up with Aurasound NS3-193-8A. Madisound said they are good for F3@120Hz in a 1L cab.
Old 25th September 2010, 05:52 PM   #3
loninappleton is offline loninappleton  United States
The Cornu and it's variants get discussed here from time to time.
And Scott has a design for the Fostex FE series resembling his fonkens but in the cornu style: wide and flat.
The one I'm thinking of can hang on the wall, but with any of the Cornu variations, they'll be heavy need to be secured well. And find a nice place for the wire too.
Scott and Dave monitor all the threads here so the picture should turn up if you ask.
Cornu is a proprietary design but there are plans for it in an old issue of Speakerbuilder IIRC.
Old 25th September 2010, 07:20 PM   #4
GM is offline GM  United States
GM's Avatar
Hmm, ideally you want a low 60s XO point if the sub is sitting on the floor under it, ergo mains with a maximally flat response to the same point, a lot to ask of a 4" in 2pi space without a huge cab.
If you can accept some mains/sub loss of detail through the XO BW, then upping the XO point to ~80 Hz and 2nd order minimum for example gets you a ~0.676 ft^3 vented alignment tuned around 45 Hz for the CSS EL70. Using a ~7/8" dia. vent to allow a baffle thickness vent using ~5/8" thick material construction will have a high vent mach, but damping it will 'kill two birds with one stone' by both dropping it to inaudible levels and get the desired maximally flat response required for the mentioned XO, so browsing the various small Fonken designs to see what might work seems as good a place as any to start.
Anyway, lots of ways to approach this depending on the acceptable trade-offs.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th September 2010, 08:00 PM   #5
I was actually thinking of a XO of around 100hz because I was going to put the sub under my massive desk. It is an L shape so I can move the sub around for the best sound. I'll start looking at those plans now...
Old 25th September 2010, 08:43 PM   #6
chris661 is offline chris661  United Kingdom
chris661's Avatar
This design uses a 5" wideband, with helper tweeter.
Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories A cabinet design similar to this could well be in order...
My work: www.grimshawaudio.com
Old 25th September 2010, 09:34 PM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
And Dave has a design for the Fostex FE series resembling his fonkens but in the cornu style: wide and flat.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th September 2010, 09:36 PM   #8
frugal-phile(tm)
planet10's Avatar
The microTower Home Theatre Appendix (in the ML-TLs) has a number of wall-mounted CHR-70 enclosures
dave
Old 25th September 2010, 11:13 PM   #9
WOOHOO!
Old 26th September 2010, 12:10 AM   #10
dave
I stand corrected. On those pages the Alpair 7 "Studio Monitor" double base reflex looks like an interesting build.
HELP, I need a full ranger that I can hang on the wallHide this!Advertise here!
has anyone tried Venture Full/Wide Ranger? _henry_ Full Range 3 9th February 2009 07:04 AM
Fostex full-ranger for in wall use :-) sharpi31 Full Range 4 5th March 2008 11:46 AM
Full ranger and a woofer question audiophile36 Full Range 25 25th February 2008 08:54 AM
not really a full ranger Nanook Full Range 3 3rd April 2006 09:20 PM
Beyma 5MP60/N as a full ranger? Elias Full Range 2 25th November 2004 12:37 PM
