Cheap & easy cylindrical column loudspeaker - Page 2 - diyAudio
Old 21st September 2010, 01:31 AM   #11
gpapag is offline gpapag  Greece
gpapag's Avatar
Edit time for post #9 expired , so I will post the intended edit here:
PS2: Due to the fact that untreated roll carton is quite lossy, impedance plot might show an aperiodic loading. If this is the case, the exact hight of the cylinder is not important at all.
George
Old 21st September 2010, 03:58 AM   #12
norman bates's Avatar
nice pics, love the huge blue cone over the full ranger. Not my cup of tea, but nice.
Norman
Old 24th September 2010, 01:26 PM   #13
gpapag's Avatar
Thank you Norman.
Hi all
I made a smaller reflector for the tuby enclosure. This reflector, as the larger one (the circular speaker baffle as well) is made of two roll carton pieces glued together using silicon bathroom sealant. It takes 1/2 hour for the sealant to set, but it's acid smell takes 2 days to go away out in the open.
Old 24th September 2010, 01:29 PM   #14
gpapag's Avatar
The sound using the small reflector is perceived as more detailed compared to the sound with no reflector and more open and detailed compared to the sound with the large reflector.
Next, I covered (glued with office paper glue) the small reflector with kitchen aluminum foil. Contrary to what I was afraid of, the sound did not become edgy and aggressive, but one more step higher in details.
This is a good progress up to here.
Thanks for reading.
George
Old 1st October 2010, 11:15 PM   #15
gpapag's Avatar
Default Cosmetics
Dressing-up a Lady with a stretchy dress (Crepepaper)
George
Old 3rd October 2010, 11:45 PM   #16
Default complements
I love this idea! Nice gesture for a relative with good execution for longevity. My compliments!
Old 5th October 2010, 07:52 AM   #17
gpapag's Avatar
Thank you gvimhoof.
I enjoyed the photos of your speakers in the Gallery. Very good construction and the choise of colours is superb!!
George
PS: We are living in the same city (on a different continent though)
Old 25th December 2010, 09:27 PM   #18
gpapag's Avatar
Hi all
I have done a few changes to the speakers.
First two 6.5 inches drivers were installed. They were removed some 10 years ago from an old Ford Granada.
Some mods (whizzers removed, paper cone treated with shellac -5 passes- and plumper’s putty around the magnet) made it sound better to my ears.
Then paper roll Tube bottom raised 5cm above the floor through stands, making for an open-end pipe.
Impedance Plots:
Pink: Speaker on air.
Red: Speaker on closed-end pipe.
Green: Speaker on open-end pipe.
File Type: jpg impedance sweeps air-closed tube-open tube.jpg (104.9 KB, 29 views)
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 25th December 2010, 09:36 PM   #19
gpapag's Avatar
Next, the tube top was cut ~20 degrees from horizontal. Turning each speaker around it’s vertical axis, allows for directivity and off the wall reflections control, without using reflectors on top of the speakers.
Two larger 29cm dia circular wooden baffles and wooden phase plugs were prepared and tested, but rejected by the user (“too serious looking” and “these silly projecting things” were the comments for the baffles and the plugs respectively).
Therefore phase plugs removed and wooden baffles replaced with paper baffles dressed in red.
Old 25th December 2010, 09:42 PM   #20
gpapag's Avatar
Positioning the two speakers close together instead of having them separated by a distance as is normal for stereo, gives a better over all performance at least for this room and listening positions.
Freq Response:
(Pink): Tube Out.
Mic on Carpet 0.03m below Column Output
(Red): Close-Up Both Speakers.
Mic 0.3m from Speakers Center, Baffle Level , Horiz Position
(Green): Far Both Speakers.
Mic 1.2m from Speakers Center, Baffle Level , Horiz Position
(Blue): Ambient Noise. No Signal to Speakers.
Speakers driven through the External Ampl Headphone (L) Out.
Amp. Volume Control: Max (Fully CW)
Piezo Mic through Mic Pre to Soundcard (C-Media PCI Audio Device)Line In
Room Eq5 Settings (Log Sweep):
Sample Rate: 44.1k
Word Length 256k
Sweeps:2
Actually the merit of this “one spot” speaker placement is something that I am after some time now.
I don’t know how to test the validity of such a hypothesis-or luck of it- by acoustic measurement. I am open to suggestions.
George
<edit> First plot is with 1/48 Octave smoothing.
Second plot (1/3 Octave smoothing), for just to make trends easier to see
File Type: jpg smoothed (1-3 oct) fr resp overlay.jpg (113.4 KB, 21 views)
How to design a loudspeaker in 3 easy steps using WinISD. Wella Full Range 18 7th August 2010 04:22 PM
Quick, Cheap & Easy ESL ideas thread bigwill Planars & Exotics 9 3rd March 2007 08:56 AM
Easy Loudspeaker Measurement System Set Up hongrn Multi-Way 3 24th July 2006 08:56 PM
Cheap, small, and easy to build (pcb) amp for studio? massappeal129 Solid State 2 1st March 2003 12:23 PM
first easy cheap ect... theChris Parts 5 31st January 2003 07:00 AM
Copyright ©1999-2017 diyAudio
