Hello All. I am very tempted to build a full-range speaker enclosure but I am finding all the options rather overwhelming... Based on initial reading:
1) Speaker choice? I've been thinking a Fostex FE206en...the Fostex 208 Sigmas also look interesting but appear to be a lot more expensive than the 206. Am I better off staying with the 206s? 2) The enclosure options are making my head spin! Characteristics I'd be looking for: - I'd be looking for something that offers decent bass. I don't have good high frequency hearing so I am not overly concerned with upper-range frequencies. - Easy to build? - Versatile: I have an eclectic music taste - ideally looking for something that could work for Bach to James Brown to Black Sabbath to Hip Hop. - Medium sized room - about 16'x16' with 8' high ceilings. 3) The intent is to feed the speakers with a low-wattage (3.5w) tube amplifier. My general dilemma is that there are so many different options. Would appreciate it if someone can help me get focused into the right direction. |
#2 |
frugal-phile(tm)
FE206 is a good starter choice.
Having too many choices is way better than too few Start a list of potential enclosures and then start eliminating them. They really want a horn. Let me get you started: RonHorn Dallas II Spawn Sachiko (small room probably scratches this one) BIB Metronome the new Woden V-Series HM probably has some... dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Are you looking to build your final, ultimate speakers right off? Or is this the start of a hobby?
How good is your woodworking? What tools do you have access to? How important is appearance vs. sound quality? With that level of power, you are probably looking for >95 dB efficient. The BiB (Bigger is better) is known for good bass, easy to build and highly efficient with the right driver. They are large, but good bass with high efficiency generally demands a large box. |
#4 |
Hello,
may be this could be a solution: Sats with sub for small rooms Trumpet-Sat Schalmei-Sat sub alphorn or double horns like Saxophon and RDH20 extrem good Impedanz for Tubes. surf my HP oh thanks Planet10
http://www.hm-moreart.de Last edited by hm; 17th September 2010 at 11:11 AM. |
#5 |
Hi Everyone, thanks for the input.
My carpentry skills aren't the greatest and I don't have much equipment, so the simpler the better. - The Dallas 2 looks difficult to build. - The Sachiko looks nice but possibly expensive and a labour of love? (Plus if it doesn't work well outside of big spaces then probably not worth it?) - I like the simplicity of the BIB cabinets and that they appear to have good bass. - The metronomes look nice and easy to build, but bass is weak? - Can't get much info about the Woden. So far it looks like the BIB boxes are the best bet!? The main challenge being size... Any recommendations for where to find the best BIB plans? Or can I just use the BIB calculator spreadsheets to figure it out for myself? Thanks. |
#6 |
1) Should I consider the FE 166 as well, or am I better off sticking with the 206? I'm not sure what the trade-offs are between the two speakers. I'm assuming the 206 has better bass.
2) Are Fostex's website box plans any good? Or am I better off sticking with a home designed BIB? |
#7 |
a few quick thoughts:
It's hard to get the fullest level of wide-band performance and finesse from drivers such as 126/166/206 / AudioNirvana / Lowther, etc., without enclosures as elaborate as any of the numerous BLH / Olsen style manifold designs mentioned yet or to follow, and the accompanying build complexity Math for BIB has already been done for many popular drivers (see Jeff's site for dimensions and build suggestions) Bigger Is Better 'BIB' Cabinet Dimensions - ZillaSpeak much the same for Metronome: The Metronome Some of the Fostex larger BLH designs work quite well enough, but are at least as time consuming a build as any others under consideration. The simpler sealed/BR or "hybrid" enclosures, not so much performance-wise. Woden designs continue to evolve, and as you might imagine, one guy can only accomplish so much. Being more fastidious and particular about optimizing enclosures to driver T/S parameters than many of us, (speak for yurself, Chris edit: for a room your size, I'd be surprised if the FE166 didn't work quite well enough There will of course be those who opine that no single driver/FR system can do it all (particularly HT or metal, etc.) and as my listening habits have "matured", I'm not one to argue that point. But it's pretty easy to supplement any of these FR speakers with as many powered woofers as needed.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 17th September 2010 at 06:59 PM. |
#8 |
Not sure anyone has built a BIB for the new 206en. Try the BIB Calculator and see what you get... I bet a few here will check your math, including me, so you get something really worthwhile. If you plan to put the speakers into corners BIBs are a great choice for full range drivers.
#9 |
What does the 'fr' refer to in the BIB calculator?
#10 |
| Desperately need SEAS P11RCY08H454 | richard pfeffer | Swap Meet | 0 | 23rd July 2007 06:43 AM |
| Desperately Wanted !!! | ROCKMANDRAKE | Analogue Source | 0 | 28th October 2005 02:32 PM |
| Desperately looking for: Tripath TA0102A | Anders213 | Swap Meet | 0 | 26th May 2005 11:17 AM |
| I Need A Pot Desperately!!!! | nfway | Parts | 7 | 20th July 2004 05:51 AM |
| desperately need help with finding componenet! | wud-e | Parts | 1 | 6th February 2004 05:21 PM |
| Page generated in 0.10849 seconds (84.51% PHP - 15.49% MySQL) with 11 queries |
