First timer - desperately confused with the options... - Page 2 - diyAudio
Old 18th September 2010, 03:14 AM   #11
frugal-phile(tm)
planet10's Avatar
Originally Posted by platplaas View Post
See the pictures:
No. Instead of linking to pictures that won't display outside of picasaweb, attach them to your post.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th September 2010, 03:33 AM   #12
Default Try two: Images attached
I'm learning, slowly but surely...
Images are this time attached to the message:
Old 18th September 2010, 04:02 AM   #13
frugal-phile(tm)
planet10's Avatar
Looks good...
dave
Old 18th September 2010, 04:12 AM   #14
Cool Corrected image - dimensioning error
I made a width dimensioning error with the first image. Corrected image is attached.
Also, thus far I have assumed that Fr means Fs. Please let me know if I have this wrong.
Thanks.
Old 18th September 2010, 04:17 AM   #15
frugal-phile(tm)
planet10's Avatar
I sure makes sense if it is.
dave
Old 18th September 2010, 08:12 AM   #16
Scottmoose's Avatar
It will do.
Old 13th October 2010, 06:12 PM   #17
Default Materials and Joints
I'd like to start building the cabinet...what is recommended for:
1) Materials - MDF vs. PLywood?
2) Thickness - 19mm?
3) What is the best way to build the joints? Should I caulk the joints? Use adhesive on the joints or fasteners like nails or screws?
4) What to place under the cabinet? Spikes?
5) Any recommended wires and connection parts to use?
6) What to use as insulation / damping materials?
Thanks!
Old 13th October 2010, 06:28 PM   #18
chrisb is offline chrisb  Canada
Thanks!
amazing, not a single contentious item on the list
on hiatus
Old 13th October 2010, 07:04 PM   #19
Default Contentious
Ha...well, let me help by saying that the simpler and more affordable, the better! I have limited tools, and hope to achieve good value for money.
Old 13th October 2010, 07:46 PM   #20
Godzilla's Avatar
LOL Chrisb!
1) plywood will sound better
2) if 19mm is .75" then that's great - but i like to double up the front and back
3) i use butt joints, glue and screw but i am a hack carpenter
4) i nailed little metal furniture feet to mine
5) some here will say CAT 5 (which i used in mine) but i think 16g wire is fine too
6) i used acousta stuff
If you put spikes on the bottom of your BIBs you may scratch up your floor when moving them. Sometimes i think about adding handles on the sides to help move them. When i do move them, i hug them close and hump them around into position.
Enjoy them!
Zilla
Desperately need SEAS P11RCY08H454 richard pfeffer Swap Meet 0 23rd July 2007 06:43 AM
Desperately Wanted !!! ROCKMANDRAKE Analogue Source 0 28th October 2005 02:32 PM
Desperately looking for: Tripath TA0102A Anders213 Swap Meet 0 26th May 2005 11:17 AM
I Need A Pot Desperately!!!! nfway Parts 7 20th July 2004 05:51 AM
desperately need help with finding componenet! wud-e Parts 1 6th February 2004 05:21 PM
Copyright 1999-2017 diyAudio
