Old 15th September 2010, 05:37 AM   #1
Send a message via AIM to BADFISH51
Default Speaker help
when the parts arrive I'll be building my first amp, a 41Hz Amp6-basic. However, I'm having no luck finding a cheap diy speaker setup. Plus, the lack of wood working tools (Router & biscuit joiner) leave's me no other option but to buy some bookshelf speakers. Here's what I found so far...
Insigna NS-B2111
Paradigm Atom V.2
Dayton B652
MTX 5i
which have the best sound? They will be used mostly for music and movies.
Old 15th September 2010, 01:34 PM   #2
GM is offline GM  United States
GM's Avatar
This is sad commentary on the current state of what constitutes a minimum tool set for DIYing speakers or woodworking in general. Sorry, but this is a DIY forum where these types of tools are a luxury, not a prerequisite, so while I've read some good things about Paradigm monitors many years ago that doesn't mean this particular model is on a par with them and the others are just names to me. Your best bet then is to try these consumer speaker forums or similar:
Speakers - AVS Forum
Home Audio Speakers at Home Theater Forum and Systems - HomeTheaterShack.com
Now if you decide you can make do with butt joints, glue blocks and have enough manual dexterity to use basic hand saws, caulking gun and the desire to DIY some single driver speakers with maybe a super tweeter, then you've come to right place.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th September 2010, 02:01 PM   #3
Scottmoose's Avatar
Seconded.
I'm lousy at building things, but the last large pair of cabinets I made were done with a 30 year old handsaw, cheap jigsaw, rasp, & file. No, they weren't exactly commercial-pretty, but the dimensions were accurate, they were solid and they worked, so if muggins here can do it, I'm sure you can. If you really can't manage that then you could always find a design you like & get your local tame cabinet-maker or a suitably reimbursed friend to build them.
Old 15th September 2010, 02:18 PM   #4
Godzilla's Avatar
Agreed. I have nothing but a very old hand saw from my grandfather, a new drill, electric sander, screws, glue and a bunch of clamps. I draw out measurements on paper and bring to Home Depot.
As for the speakers mentioned, i had a pair of Atom's years ago after reading many rave reviews. I returned them. They are one of the reasons i build my own speakers.
Good luck building your amp!
Old 15th September 2010, 02:37 PM   #5
chris661's Avatar
First off, good choice of amplifier. They sound lovely. I use mine with a 60w laptop PSU, and it gives plenty of volume when called upon.
I'm just finished some of these...
http://www.diyaudio.com/forums/attac...e-ml-voigt.gif
They are very very good. They go pretty low (usable output around 40Hz in room), but are still over 90dB efficient, which is plenty. They use the FE126 from Fostex (I used the FE126E, fully treated by Dave to make them eN).
I suspect that the new FE126En would work, but I'm no expert on these voigt pipes...
Still, they'd be my recommendation. It's not as simple as a standard box (one more piece and a small port is needed), but the results are definitely worth it.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 15th September 2010, 06:39 PM   #6
Alright, I'm going to build! Any recommendations?
Chris, they look interesting. Do you have the filter schematic?
Old 15th September 2010, 08:06 PM   #7
Scottmoose's Avatar
Hold fire a moment. Some points to consider:
So. What sort of sound balance do you like? How large a cabinet can you handle and what type? What sort of material do you listen to? How much can you afford? How large is the room and how far away from the speakers will you be sitting? Once you've given us a few details, we'll be able to give you a few ideas.
Old 15th September 2010, 08:07 PM   #8
jrenkin is offline jrenkin  United States
If you have some space the BIB is extremely straight forward and hard to beat.
Old 15th September 2010, 08:53 PM   #9
Since, this is my first project I would like to keep cost low $115 max not including the MDF.
Project outline
Sound Balance: ? I'm a noob
Project Cost: 100 +/- 15%
Cabinet Size: Any, limit to 1 4x8 sheet of MDF.
Music: Rock, Heavy Rock, & Slow Rock.
Room Size: Medium
Distance: 4-10ft
Old 16th September 2010, 12:16 AM   #10
Godzilla's Avatar
I built this a few months ago and was thinking of selling it as a kit... but probably will change my mind. It's the dayton 6" woofer plus a piezo crossed at around 6khz in a .5L box tuned to 70hz. It sounds really good and punchy and will cost less than $100. I think it's a good alternative to the speakers listed above... but it's not perfect, LOL!
I am going to play with the 5" daytons when they are in stock again. I have been thinking cheap... but good.
Zilla
Re-Jigging the jig: Speaker testing device for Arta, Speaker Workshop & HOLMImpulse MJL21193 Multi-Way 263 9th January 2012 11:24 AM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 34 17th June 2011 03:07 AM
New Flat Panel Speaker 2x2 speaker set for sale (3800 sets) Tenacious Vendor's Bazaar 0 18th June 2010 12:17 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 10:12 PM
Page generated in 0.11516 seconds (80.73% PHP - 19.27% MySQL) with 11 queries
