I grabbed a super cheesy pair of Noresco 511 bookshelves at the thrift for almost nothing, not even knowing what driver hid behind the non-removable grille: but I knew it was a single 6 incher, from feeling the cutout.
As I suspected, a Philips fullrange, model AD7060/M8. Ceramic magnet, whizzer cone. Otherwise similar-looking to the older quad of AD2700 I got a while ago: same basket, same cone and surround but different magnet, whizzer a bit different, dustcap is not the same as well. Hope their Qts turns out to be a bit lower than the 2700's 0.9 that kind of limits their applications. Here are some pics: AD7060_a.JPG AD7060_b.JPG AD7060_c.JPG Will run some test to get T/S parameters and post back here. az Last edited by IG81; 15th September 2010 at 03:13 AM. |
#2 |
I finally got around to measuring the AD7060's parameters, here it is for reference:
Philips AD7060/M8 T/S parameters (average of two units w/ very little deviation) Znom: 8 ohm Re: 7.85 ohm Fs: 46Hz Qms: 3.36 Qes: 0.875 Qts: 0.694 Vas: 46.1 liters Sd: ~133cc SPL: ~89dB/W/m Played around a bit in WinISD and they seem like they would be happy both in sealed and BR enclosures, with a slight hump in the bass. They could do OB as well, without expecting foundation-shaking bass. Might also be interesting in a TL. IG |
#3 |
Turns out an error slipped in the previously calculated parameters, here is a revised version.
Znom: 8 ohm Re: 7.7 ohm Fs: 44Hz Qms: 3.01 Qes: 0.62 Qts: 0.51 Vas: 50 liters Sd: ~133sq.cm SPL: ~90.5dB/W/m I tried the drivers in ~20"x30" foam open baffles, placed on the floor, drivers in the center, angled upwards a bit with no toe-in, so as to listen to them a bit off-axis. They sound pretty darn good! I was surprised actually. The 4 AD2700's I got a while ago sound kinda tinny and canned-up, but these have none of that honk I dislike and, with simulated BSC on the EQ, had pretty decent bass for such small OB's. The highs do roll-off at some point, but they are not fatiguing in nature and quite mellow. A super-tweeter could be added, but one could live without it as well. I might have to build something more serious with these! IG |
#4 |
I decided to build some aperiodic boxes for these drivers. I know there is no real advantage performance-wise to aperiodic boxes versus acoustic suspension; all it should do is allow better performance out of a smaller (non-ideal) box. In essence it helps out a compromised design.
I plan to build an acoustic suspension of smaller volume and gradually drill holes in the back, fill them with foam or cut a slot, glue a woof piece over it insid the enlosure, then cover it with fiberglass insulation ala Dynaco, and drill holes under it. I would both listen subjectively and test the system's LF impedance after each hole until I get it back down to a Qtc ~ 0.7 and/or like how it sounds. The question is, how much can I expect to get away with, compromise-wise? For a Qtc of 0.7, I would be required to build a 57L enclosure. I currently plan on a 28.4L enclosure, which will rise Qtc to ~0.84. It will be stuffed, somewhat reducing this figure. I think this is a sensible enough plan. Any opinions? Thanks, IG Last edited by IG81; 1st October 2010 at 02:12 PM. |
#5 |
Hi IG,
this is a good small driver, much better than some modern. I use this speaker onetime in a bowl (not so good) and first time in Back vented special case. ![]() Mineīs a little bit different, called AD 7061/M4 in 4 ohm. I have used this with an old Tuberadio with Loudness. Also, in this dimension thereīs a chassis, nearly look similar basket and paper, with Alnico-Magnet. Donīt know the number. I think itīs AD3700, built in my Speaker for kitchenradio. ![]() ![]() nice greatings, Hatti
The step from genius to crazy, is very small! Please call me crazy, so I donīt have to declare! |
#6 |
Cool! Nice to see others are finding/using the same driver!
My pair ended-up in an aperiodic box, where it performs decently, depdending on source material. It has now been superceded on practically every level by my Karlson kouplers with Philips AD9710 and Richard Allan CG10T. I could see the AD7060 in a K8-size koupler. Thanks for your input! IG |
#7 |
Following this, there's an Alpair 10 in the picture. Are you suggesting that the old Philips is much better compared to A10? No offence to both sides, I myself use and love both old and new. Just wondering how exactly your feel about them. |
#8 |
Hi CLS,
I agree there are good speakers in the past and now. But not the A10. yes, all this 3 Speakers are much better than the A10! You can use the old one without any filter and they are louder than the A10, by the same power you put in. I test this 4 Speakers in a bowl l d=37,5cm, V=ca.27 Liter HR= d: 4,3cm long: 5,5cm 42,5Hz Helmholtz resonator Chassis: Philips 7061 The A10 is realy not my way! And I canīt believe, why so many people love this. This is A10 reality: (my 45 years old Ear is messurement) A10 in the bowl: 20Hz Membran moves, no sound 30Hz something, very quit 40Hz powerfull, but less than 1000Hz 50Hz a little bit louder, maybe same 60Hz same as 50 100Hz more 125Hz same as 60 250Hz little bit more 400Hz little bit more 800 Hz more 1000 Hz same 1250 Hz same 2500 terrible loud (you need a filter!) 3150 same 4000 getting less 5000 same as 4000 6000 getting less 7000 terrible loud (you need a filter!) 8000 very silence 9000 a little bit louder 10000 and follows: get less up to 15000 my Ears close. ![]() You can compare this with the real offer. Test this yourself or donīt waste your time using an A10... Nice greatings, Hatti
#9 |
I had 4 AD2700, that were very similar to the AD7060 and the AD3700 you posted, but they did not sound very good. They had much higher Qts, ~0.9 IIRC and a very canny midrange.
IG |
| Philips AD8080/M8 | lochness | Full Range | 1 | 15th June 2008 05:40 AM |
| Fostex FE206E or Philips AD 9710 M8 | 69122s | Full Range | 14 | 6th December 2007 09:29 AM |
| Advice for Philips AD12202-M8 | edlye | Full Range | 5 | 14th September 2007 12:19 AM |
| Philips AD70850 M8 | PTSOUNDLAB | Full Range | 22 | 5th June 2007 05:35 PM |
| Philips AD7060/W4 | ziggi | Multi-Way | 3 | 8th November 2006 02:06 AM |
| Page generated in 0.10845 seconds (87.46% PHP - 12.54% MySQL) with 11 queries |
