#2 |
1. May I ask what tool you used?
2. Interesting that there are ~5 peaks, and ~5 big bends in the horn. I guess that's obvious though! 3. Would it be correct to say that the F3 is ~40hz? That's just a wild guess from your impedance plot. 4. How do you like them? |
#3 |
7 major bends actually.
No, quite correct. Welcome to the laws of physics where when mouth size is compromised over the optimal for a given Fo, the acoustic impedance is no longer fully resistive & we're relying more on resonant action. Bends aren't particularly an issue, as you can see from the attached. Top = Saburo horn unfolded, expanding cascade of straight manifolds. Bottom = unfolded horn with same St, Sl & basic flare profile but with continuous expansion. Short of damping them per a TL, this applies to any pipe or 'cone' / expanding pipe with a compromised terminus area. And most are (unless you've room for a horn with a 50ft^2 mouth CSA. Per cabinet). Last edited by Scottmoose; 10th September 2010 at 05:05 PM. |
#4 | |||
The software is Speaker Workshop. I built a Wallin Jig2 for the soundcard interface. I'm just using the SigmaTel audio built into my laptop.
#5 |
Depends on the room but F3 will typically be 40 - 45Hz.
Aperiodic boxes are basically (leaky) sealed cabinets, so yes, they will only have a single impedance peak. A BR cabinet should possess two. An expanding pipe will possess a variety depending on length, flare profile, throat & terminus areas unless it is impedance matched down to its design cut-off, i.e. full-sized. |
#6 |
Fascinating, gentlemen! The Harvey is still one of my all-time favorite speakers (built by Phil Townsend) and I've been curious about the Saburo.
Scott, many thanks. Would it be too simplistic to think that each peak/dip roughly corresponds to the QW resonance of a manifold (not that it necessarily matters in the larger picture)? |
#7 |
Ty_Bower,
thank you very much for your measurement, now i know what membran movement is happend and that a tube amp will have a problem in comparison to my real double horns, thanks.
http://www.hm-moreart.de |
#8 | |
Only a bad one (as in valve amp). The vast majority of people who have built these cabinets run valve amplifiers to the best of my knowledge, and most have been quite happy with the results. As far as I'm concerned, that's all that matters.
Why the 'real'? They're completely different enclosure types. Your boxes (at least, the ones I assume you are refering to) run twin drivers in a bipolar configuration, each loading a highly compromised damped horn / expanding pipe differentially tuned to fill in the harmonic nulls. Saburo is a large, forward firing bifurcated catenoid horn (somewhat less compromised, though these things are relative) with an MTM style terminus configuration. Trying to compare them is a bit like comparing a snake with a baboon: pointless. Not that it makes much difference given that Saburo is obsolescent. You will have noticed, I trust, the rather accurate correlation between the graphs posted above? Quote:
No, it's not got much to do with the manifolds per se; that was the point I was making with the above two graphs. Forget folds for a moment: just assume it's all straightened out i.e. heading in the same direction. Top plot is just that, lower plot is a horn with the same throat & terminus area as Saburo, and the same basic flare profile it approximates, but with continuous (i.e. smooth) expansion. Not much of a difference, right? Most back-horns are not impedance matched down to cut off. They can't be; you need huge mouth sizes to do that, so they rely on resonant action on the bottom end until they reach impedance-matching higher up. Last edited by Scottmoose; 10th September 2010 at 07:13 PM. |
#9 |
Hi Scott, thank you!
I've never seen (or at least noticed) harmonics on an impedance plot, and it looks like that's what is there (e.g., on your top graph, peaks seem to be multiples of ~30, the dips multiples of ~45). So I gather that "impedance matched" would mean "designed to have a flat impedance" (sorry to be dense)? |
#10 |
Not exactly. As noted above, it is in reference to compromised terminus size. When terminus area of a horn is undersized, as it almost invariably has to be for bass horns, you get a standing wave (supersonic shockwave) reflected back along the horn path. Horns are basically impedance matching devices, viz. matching the high impedance of the diaphram to the low impedance of the air, and thereby improving efficiency as the driver is 'seeing' a constant resistive load at all frequencies in its functional BW. Nominally horn terminus circumference should be a minimum of 1 wavelength of the lowest frequency to be reproduced in order to avoid this; depending on localised SoS for a 40Hz horn you're looking in the order of termini areas of 50ft^2+. More to it than that as you need to consider boundary loadings, whether a particular horn is reactance annulled (back horns usually aren't, although it's technically possible); you also need to be careful in other areas -Keele has demonstrated that beyond a certain mouth size efficiency will begin to drop away.
| New Saburo Build thread | Wha' DIYa know? | Full Range | 94 | 17th October 2010 04:49 PM |
| Saburo build question.... | PDRCanada | Full Range | 4 | 16th August 2010 08:11 AM |
| Peerless 830883 damage from shipment (impedance plot) | giralfino | Multi-Way | 2 | 7th June 2010 08:09 PM |
| impedance plot on vented box? | dallaire | Multi-Way | 3 | 1st January 2008 09:21 PM |
| Impedance plot BG Neo8 PDR | Jeroenkv | Planars & Exotics | 2 | 5th June 2006 04:11 PM |
| Page generated in 0.10541 seconds (86.49% PHP - 13.51% MySQL) with 11 queries |
