Will the EL70 work in the Chr70 Pensil design or will it have to be modified?
#2 |
frugal-phile(tm)
Probably needs some modification.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
#4 |
frugal-phile(tm)
Let's see what Scott has to say.
dave
#5 |
I'm not doing a Pencil for the EL, but of the existing enclosures, the CHP cabinet will be the most flexible.
#6 | |
Also, how would it change the sound if the driver was placed closer to the top of the cabinet? Is there a reason that the driver is placed lower? |
#7 |
Because I designed the Pencils for Mark's range.
Don't do it. You'll screw the alignment up. |
#8 | |
This is the problem I had when loading them into an existing MLTL of similar dimensions as the Pensil except with a 2" ducted vent that over-damped them somewhat, consequently overemphasizing the driver's inherent sibilance up in its break-up modes BW, something I can't tolerate in any speaker since it painfully changes the pitch of my tinitus. By the same token, others hearing and/or playback system may be such that this is beneficial, so as always when someone wants to use a driver other than the one a speaker was designed for it boils down to whether they are willing to gamble some time/materials building at least one prototype to see if it can be made to work or a complete new design is required. High aspect ratio vented cabs once long enough will have closed pipe 1/4WL resonance modes that affect driver loading, so if the driver is at the closed end it will get the maximum loading, ergo the widest resonant BW. Usually a good choice for a (sub)woofer app where its resonant HF BW will be rolled off with an XO, but not so much for a wide BW one since it means more BW to damp. Moving the driver down the pipe then equates to less damping required if the right spot is found. This point varies based on the pipe's dimensions, so refer to MJK's Classic TL Alignment Tables doc for close enough calculated solutions. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#9 |
Ouch. I can feel that (re the tinitus).
The EL in the CHP box will likely need about 3/4lb of dacron evenly distributed through the box (about 0.6lbs./ft^3); how severely that'll mass load the diaphram though I'm not sure. Judging by your experience Greg, probably not ideal. |
#10 |
My goal was to try to salvage the Pencil cabinets that I started for the CHR-70. I was not crazy about this driver even after the recommended 100+ hours so I sold them. Was hoping to try the EL in these boxes but now I'm not sure.
Either way, I just finished the cabinets and for now I cut the holes smaller and put in my trusty pair of 871s and they sound pretty damn good - better in fact than in the Needles. |
| Pensil Series for Mark Audio Drivers | planet10 | Markaudio | 46 | 28th September 2011 07:19 PM |
| Pensil 12 and B&W Matrix 802 | goneill | Markaudio | 65 | 26th April 2011 04:31 AM |
| PVC Alpair 6 Pensil | guglielmope | Markaudio | 18 | 27th June 2010 07:07 AM |
| Pensil-70 sub Crossover | snafu79213 | Full Range | 3 | 18th April 2010 08:30 PM |
| Floorstander with EL70 | AlejandroR | Full Range | 16 | 20th December 2009 04:22 PM |
| Page generated in 0.10722 seconds (83.73% PHP - 16.27% MySQL) with 11 queries |
