Old 7th September 2010, 07:48 PM   #1
Godzilla's Avatar
Default Voigt Pipe for TB W8-1808
I have been enjoying the TB 1808 on open baffle for several months but wanted to do something else on open baffle and maybe put these drivers into Voigt Pipes similar to what Lowther does.
http://www.parts-express.com/pdf/264-894s.pdf
I like the dimensions of this cabinet:
FredT300B's Photos : Popular Photos : These are the plans for a pair of Voigt pipes built by Herbert Jeschke, taken from the single driver website at http://www.melhuish.org/audio/DIYTQ4.html The Voigt Pipe is a Tapered Quarter Wave Pipe enclosure, w
I don't know how to design a pipe like this (only BIBs, ported, OB and sealed boxes for me) and was curious how to do it. I wanted to make sure the performance will be optimal before cutting wood. Can someone help me with these dims and port opening please? I prefer a square port like in the drawing. But really, i'd like to be able to sim this cabinet on my own. I built the straight pipe (brines) years ago and my son wants them in his bedroom bc he likes the look (they don't have drivers in them at the moment tho they used to have RS 1354 and then Fostex 127e... and may end up in his room with Fostex 168s old style with wizzer... lucky kid!).
I think the 1808 will work really well all by itself in this type of cabinet with out bass or treble support.
TIA,
Zilla
Old 7th September 2010, 09:19 PM   #2
I'm no help with your question, but wondering if you've been using the 1808s with a Zobel network or just "naked"? I'm still torn between using mine in some sealed cabs vs. open baffle (with some bass augmentation in both cases).
Old 7th September 2010, 09:38 PM   #3
Scottmoose's Avatar
They'll work Jeff, but they'll need a relatively big box to do so given the middling Q & Vas. How large a cabinet are you willing to go to?
Old 7th September 2010, 10:29 PM   #4
Bob Brines's Avatar
I hate to burst your bubble, but 1) the Lowther Club of Norway pipe is a God awful design, even for the PM6C that it was designed for and 2) the 1808 has exactly the wrong parameters to even semi-work in that cab. Model this combo and see what I mean.
Bob
Old 7th September 2010, 10:50 PM   #5
Scottmoose's Avatar
Agreed, although if we ignore that particular box & just use Voigt Pipe as another term for mass-loaded conical horn, then they should do OK in a (large) cabinet of the general MLCH type.
Old 8th September 2010, 01:25 AM   #6
Godzilla's Avatar
>>> Agreed...
Killjoys!
Yes it models big BIBs. Thanks for the insight.
Godzilla
Old 8th September 2010, 02:56 AM   #7
GM is offline GM  United States
GM's Avatar
Yeah, we had discussed doing a SS for this along time ago, but there didn't seem to be any interest in it. Regardless, I dug out my old pre-T/S pipe horn designer and mixed n' matched with the BIB one to generate a classic alignment like shown in Thuras's patent and a higher tuned one to get a bit of mid-bass 'slam' out of a typical FR driver, though of course at the expense of LF extension.
Still got to try it with a variety of drivers to make sure it's flexible enough and clean it up, so let me know if there's enough interest before I spend any more time on it. Here's the 1808's two in the same 72" i.d. high, ~9.66 ft^3 net Vb except the higher tuning uses the Voigt Pipe Sm:Av ratio and the lower tuned is my old one (0.25 lbs/ft^3 stuffing density):
GM
File Type: gif TB W8-1808 Voigt Pipe variant - high_low tunings.gif (25.3 KB, 280 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th September 2010, 03:13 AM   #8
Godzilla's Avatar
Thanks GM, i will be noodling around with that the next few days... seems like a big cab.
Old 8th September 2010, 08:40 AM   #9
Scottmoose's Avatar
Yeah, pity that SS never got any further. I think there'll be interest Greg. I've done a very limited one, but it doesn't give much tuning leeway -yours sounds like being a whole lot better.
Old 8th September 2010, 06:38 PM   #10
chrisb is offline chrisb  Canada
IINM the Norway Club "Voigt pipe" was an inspiration for one of Terry Cain's early designs that with some brilliant revisions and TC's superlative craftsmanship evolved into the Abbey
I heard these and the first pair of BIB at VSAC2001 - wow! almost a decade ago
Single Driver Website
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Tang Band W8-1808 Cabinet majerjack Full Range 30 5th September 2010 02:41 AM
Tang Band W8-1808 open baffle impressions Racket Scientist Full Range 3 23rd May 2010 03:47 PM
Tang Band W8-1808 8" Neodymium New $220 Pair Michael Rothacher Swap Meet 2 1st April 2010 06:57 PM
Tangband W8-1808 and PE Buyout Godzilla Full Range 17 23rd February 2010 04:19 AM
OB with tb w8-1808, and morel caw938 sqrivi Multi-Way 27 4th January 2010 04:37 AM
Page generated in 0.12199 seconds (79.38% PHP - 20.62% MySQL) with 11 queries
