Old 14th November 2010, 11:10 PM   #81
frugal-phile(tm)
planet10's Avatar
Excellent... that is Alpair 7?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th November 2010, 11:20 PM   #82
wagtail is offline wagtail  Ireland
wagtail's Avatar
yes A7's, i don't really know how to describe the bass its a bit boomey, hollow,not tight.
simon
Old 14th November 2010, 11:52 PM   #83
frugal-phile(tm)
planet10's Avatar
Sounds like you need more damping....temporarily you can pull them out from the wall. bass will still be fat but some of the boom should go away.
dave
Old 15th November 2010, 05:30 PM   #84
chrisb is online now chrisb  Canada
dave
Particularly the left side that is tight into the corner. I can see that the door on the right side constricts placement - does the room allow for alternate placement, perhaps with some toe-in?
It's been our experience so far that the A7 needs far less horn lift in the bottom octaves than the FE126E.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 15th November 2010, 08:16 PM   #85
wagtail's Avatar
can't do much about placement at the moment, i'll bring them out a bit and try to pull the left one out of the corner.(actually that door is not used much hmm...)
can you explain "far less horn lift in the....." please chris?
simon
Old 15th November 2010, 08:57 PM   #86
simon
Scott or Dave can better explain that part
Old 15th November 2010, 10:18 PM   #87
frugal-phile(tm)
planet10's Avatar
Proximity to walls or corner change the loading and increase the apparent size of the horn (ie in free space, the mouth radiates into a sphere, put it on the floor, half sphere, push back against a wall, 1/4 sphere, into the corner 1/8 sphere)
dave
Old 16th November 2010, 03:43 AM   #88
yoaudio is offline yoaudio  United States
I just picked up a sheet of 18mm Baltic birch plywood and
I have the beta document25-October-2010. I didn't see a cut
sheet diagram for the 18mm, just wondering if anyone had one.
Old 16th November 2010, 02:21 PM   #89
wagtail's Avatar
see page 2,post 15 for 18mm front & side elevation, i had to draw my own cut sheet for the nominal 18mm (17.4 mm ply) i used
simon
Old 16th November 2010, 05:11 PM   #90
simon
cut plan for 5x5ft Baltic birch on page 7 of
http://homepage.mac.com/tlinespeaker...Doc-251010.pdf
Note as mentioned in one of several threads, this is a very tight cut plan. I'd fabricated this pair from offcuts from other projects, so only drew this plan up after the fact. The side and front panels are laid out for maintaining grain direction if material is not to be post veneered or p-lamed.
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 389 13th May 2013 08:38 PM
Frugel-Horn Mk3 planet10 Full Range 1002 30th April 2013 04:52 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright ©1999-2013 diyAudio
