Frugel-Horn Mk3 Builds & Build Questions - Page 80 - diyAudio
Old 21st February 2013, 11:54 AM   #791
Putty tape.
Old 21st February 2013, 04:14 PM   #792
frugal-phile(tm)
planet10's Avatar
Originally Posted by valvesound View Post
I also thought that I got a good enough seal with the sticky tac.
Seal is one thing, rigidly attached to the rest of the box is another.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st February 2013, 06:11 PM   #793
Even though not rigidly attached, it would probably absorb vibration like the earthquake dampers on vulnerable buildings maybe.
Old 22nd February 2013, 05:43 AM   #794
valvesound's Avatar
Default SUCCESS!!!
Guys I am very happy to report that I am a very satisfied and happy customer
Last night I added another 20g acousta stuff behind the driver as an attempt to prevent reflections of waves coming back through the cone. I also moved the speaker to the back wall and I was in heaven!
I couldn't believe these speakers could re produce such wonderfully full, warm, clear, amazing, well balanced, enjoyable music.
I just couldn't stop listening. I found myself wanting to hear more and more different genres of music I have in my collection to see If I can fault them but I couldn't. Yes they do acoustic and female voice best in my case but rock and jazz and whatever else I had time for last night was brilliantly presented.
The quality of base these beautiful little things are capable of is just jaw dropping good. No need for a sub.
By 1 'o clock this morning I had to force myself to switch off and go to bed but I did it with a grin on my face.
I want to thank everyone on this forum for their expertise and help and for the masters that put this design together. In particular Dave (Planet10HiFi)
Thank you very much for such a great design and making it available as a DIY project!
Old 22nd February 2013, 06:22 AM   #795
frugal-phile(tm)
planet10's Avatar
I was in heaven!
Old 22nd February 2013, 06:36 AM   #796
valvesound's Avatar
Originally Posted by planet10 View Post
I still am and still have a grin on my face
Old 22nd February 2013, 07:32 AM   #797
xrk971 is offline xrk971  United States
xrk971's Avatar
Very nice!
Is it still being held together with sticky tack?
Old 22nd February 2013, 07:39 AM   #798
valvesound's Avatar
Thanks, yes, sticky tac is doing a great job! I can now move on and have the panels glued and then the big work starts with the finishing.
Old 22nd February 2013, 09:25 AM   #799
Scottmoose's Avatar
Glad you're enjoying them. Makes it all worthwhile.
Old 22nd February 2013, 04:57 PM   #800
cc570 is offline cc570  United States
Hello, first post and if any of my questions are redundant, misposted ,or based in ignorance I apologize in advance.
I assume corner loading affects only (or primarily) the output of the horn and not the driver, if so what frequencies are affected?
I ask this because I am hoping to maximize the sensitivity up to 500 - 1000hz.
And then again above 8kz or so.
What should I expect if I loaded the front of the driver with a L'Cleach flare?
Lastly, I saw that the Tang Bang bamboo cones W4 1320s worked in a FH Mk3
The W4 1337 have similar specs would these work and give the extra SPL above 8kz that I think I want?
Thanks in advance.
Charles
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 519 22nd April 2017 09:33 PM
Frugel-Horn Mk3 planet10 Full Range 1583 7th March 2017 10:34 AM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright 1999-2017 diyAudio
