Frugel-Horn Mk3 Builds & Build Questions
Old 9th November 2010, 09:36 PM   #71
chrisb is offline chrisb
Originally Posted by kristleifur View Post
Going back to this ... if you don't mind ... What about rounding over the edge? (Perhaps making two baffle pieces glued together back-to-back to create a rounded edge on both sides.)
it's been my experience that a simple 45* chamfered edge is as effective as small radius on edges, and certainly a lot easier to cut ( either on the table saw or by router) - indeed, it's become somewhat of an aesthetic signature on my builds
kinda burnt out - taking a break
Old 9th November 2010, 09:44 PM   #72
kristleifur is offline kristleifur  Iceland
One more general question if you good fellows don't mind – If I have both roundover and angled guide bits for my router, suitable to the thickness, the angle is easier to cut?
Old 9th November 2010, 09:55 PM   #73
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Look back at page 23 of Olson. If you look at the ripple caused by the rear termination of the shape you can see that it needs to be deep to minimize ripple (ie sphere vrs half-sphere, the 2 cyliders, the other truncated shapes). The size of the edge also determines the effective transition frequency. An ideal shape is something like the mid enclosure for a B&W 800 Nautilus, and clues can be had from the shape of the helmets pursuit cyclists wear.
Nothing wrong with your aspect, i'd just make it deeper, with a larger radius.
One of the beauties thou ot the removable supraBaffle is the ability to wswap out different experiments.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th November 2010, 09:58 PM   #74
THANKS! Great answers, something to chew on.
Old 9th November 2010, 10:29 PM   #75
AlanElsdon is offline AlanElsdon  England
dave
So where does the drive unit go??
Old 9th November 2010, 10:30 PM   #76
see "J" above - a thick enough square supra-baffle with 4 chamfered sides emulates a truncated pyramid on parallelopided (just for fun look that up)
I've made these as thick as 6 layers of 3/4" plywood, and cut them on table saw
Alan: I tend to locate the drivers in the center of suprabaffles, whatever their shape
Old 9th November 2010, 10:48 PM   #77
frugal-phile(tm)
planet10's Avatar
The magnet would impact his forehead... and you'd need to fill in the hole for his head with a symmetrical completion of the shape.
dave
Old 10th November 2010, 03:18 AM   #78
creosoteshadow is offline creosoteshadow  United States
I live at approximately 5000 ft elevation, where the speed of sound is approximately 2% slower than it is at sea level. Should I scale the dimensions on the Mk3 by 2% for optimal performance?
Old 10th November 2010, 03:36 AM   #79
just run your audio system on a Variac dialed for slightly higher AC mains voltage, and you should be good to go
Old 14th November 2010, 11:54 PM   #80
wagtail is offline wagtail  Ireland
wagtail's Avatar
job done! or it will be when i get round to putting a finish on them, i think they need a bit more stuffing to improve the bass.
but they sound great, many thanks to the trio.
simon
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 07:16 PM
Frugel-Horn Mk3 planet10 Full Range 1602 2nd October 2017 08:18 AM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 08:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 02:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 01:24 AM
