Frugel-Horn Mk3 Builds & Build Questions
Old 5th November 2012, 02:46 AM   #731
tlarwa is offline tlarwa  United States
Default Do I need to dampen the back side of the baffle?
In other words, around the driver? I have the back wall, side walls, top and interior panels dampened, but I wasn't sure about the back of the front baffle.
And by the way, my Dremel Multi Max saw did the trick chamfering the baffle! It's all good now
Thanks,
Tom
Old 5th November 2012, 04:29 AM   #732
chrisb is offline chrisb
Thanks,
Tom
you're fine Tom - just button up and start enjoying
like my mind, this space intentionally blank
Old 5th November 2012, 05:12 PM   #733
Default Mineral wool to line the walls?
Since I already glued it in place, I guess I'll find the answer, but I thought I'd ask...
The company I work for manufactures "fire blanket" for use in building expansion joints. The inner lining is made of mineral wool, which I can get my hands on, in unlimited quantities, 1" thick. So, I grabbed a roll, split it into 1/2" thickness and used it to line the walls of the cabinets. I assume this will accomplish what it's meant to do ... break up the standing waves in the cabinets? I know the recommendation is for the denim insulation but this was abundant and readily available. It sure looks good (I'll post a pic tonight). Any thoughts? I can always pull it off and glue in something else's guess (it would be a challenge through the top, but I think it could be done). What positive/negative sound characteristics should I listen for to determine if its doing what it should?
Tom
Old 5th November 2012, 05:24 PM   #734
Default CHP-70 Gaskets?
I have the CHP-70 enabled drivers ... are there supposed to be a mounting gaskets with the drivers? I didn't receive any if there are. Just wanted to check since the Mark Audio data sheet refers to them.
Old 5th November 2012, 05:40 PM   #735
fastbike1 is offline fastbike1  United States
The absorption characteristics of mineral wool and the recycled denim are reasonably similar. I doubt you could hear a difference between equivalent applications.
Tom
I was so much older then, I'm younger than that now.
Old 5th November 2012, 06:16 PM   #736
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Tom,
Check to see if the gasket is already stuck to the back of the bezel -- that is how i usually ship them.
If i forgot, then i will send you a pair.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th November 2012, 07:01 PM   #737
Originally Posted by planet10 View Post
Tom,
dave
Dave,
The gaskets are definitely not there. If you could drop a pair in the mail I'd appreciate it. I'll PM you with my address.
Thanks!
Tom
Old 5th November 2012, 07:51 PM   #738
Dave,
Thanks!
Tom
he does that to me all the time - luckily he's less than 10mins away.
Old 7th November 2012, 02:14 AM   #739
Default Gaskets
Dave,
Did you get my PM with my address to send the gaskets to?
Thanks,
Tom
Old 7th November 2012, 03:09 AM   #740
frugal-phile(tm)
planet10's Avatar
Yes. Packaged & ready to go.
dave
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1624 12th June 2018 08:46 PM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 06:16 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
