Frugel-Horn Mk3 Builds & Build Questions
Old 16th July 2012, 11:26 AM   #661
bullpeters is offline bullpeters  Australia
bullpeters's Avatar
And now I have got the "Tannhauser" out. 4 disc's on Decca. Poor neighbors
Old 16th July 2012, 11:44 AM   #662
yai is offline yai  Germany
yai's Avatar
Originally Posted by chrisb View Post
indeed it is
and its very easy to make: with a template of e.g. oval shape, a 40mm guide bush for the hole, a 20mm guide bush for the peace that goes into the hole, and a 10mm straight router bit for both (that's the 20/40/10 trick). The combination 24/40/8 does the same job. And the template can be any shape, as long as the smallest radius is >20mm.You have to sand it a little bit, otherwise it will fit too tight and you won't get it out again.
BTW: Trend and others (sautershop.de in Germany) sell collets that convert a 20mm guide bush into a 40mm guide bush, so you don't even have to change it.
Ring für Kopierhülse - www.sautershop.de
Old 19th July 2012, 08:18 PM   #663
ChrisMmm is offline ChrisMmm  New Zealand
ChrisMmm's Avatar
Default Felt damping material
Hi, I bought some of this Speaker Carpet - Light Grey - Jaycar Electronics which turns out to be a synthetic felt rather than wool/cotton. I was planning on using 4 layers which gives around a 1/2" mat.
However given its synthetic (you can tell when you burn a small piece) should I be using it or try and fine some wool/cotton felt? Having trouble finding any locally tho I may look to pulling up some carpet and using the old style wool underlay.
Old 19th July 2012, 10:36 PM   #664
bullpeters's Avatar
Surely scissors and a passing sheep would supply the necessary fibers
Old 19th July 2012, 10:54 PM   #665
ChrisMmm's Avatar
Nah, all the sheep here are synthetic!
Old 19th July 2012, 11:31 PM   #666
bullpeters's Avatar
I gather that the stuffing behind the baffle tightens up the bass, but what effect does more stuffing in the V have? Going to seal them up forever on monday and I am having a nervous about it
Old 20th July 2012, 04:29 PM   #667
chrisb is offline chrisb
you ever worked with raw sheep's wool? - not an experience you'll soon forget
kinda burnt out - taking a break
Old 20th July 2012, 05:27 PM   #668
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
1st off, you need a dedicated washing machine, and it should be out doors.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th August 2012, 05:52 AM   #669
bullpeters's Avatar
I had read,and tried, the packing, sealing with weather stripping,listening, adjusting and then sealing method
weather stripping with an adhesive back is the **** to remove, i resorted to the belt sander and then had to remove stuffing! I a little wiser as to re-stuffing, BUT
Make the top panel removable.....Its the best solution
Old 11th August 2012, 05:58 AM   #670
bullpeters's Avatar
Anybody building these and wondering about how much punch they have, just finished Motorheads "ace of spades" album. Last track "the chase is better than the catch", thru a 50 year old 10 watt valve amp.I could FEEL the bottom end, see it in my wine glass. Not my first choice of music but it was TIGHT thumping bass, no mush. I wonder what it would be like with really stiff cabinets.
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1603 3rd April 2018 01:31 PM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 06:16 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
