#601 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#602 |
Thanks for the update! Does anyone have these new plans in DWG/electronic format for input into a CNC router? Thanks!
#603 |
No, not in a CNC yet, but when you are doing transposing them to a cnc , please post them for the rest of us...
#604 |
I generally seal the inside of my cabinets with Bulleye Sealcoat, thin shellac. This hardens the wood surface and I wonder if it will effect the acoustic properties of the Mk3.
#605 | |
frugal-phile(tm)
dave
#606 | |
frugal-phile(tm)
dave
#607 | |
Dave - Dustin is planning on using 3/4" Plyboo, which is a true 3/4" ( 19.05mm) - I've sketched out a nested pattern for CNC machining, which includes orientation of parts for grain pattern matching. It includes oversize cutting for final sizing of the 4 parts that each require the bevel to at least one end. (the only internal part that doesn't is highlight in turquoise) There'll still be offcuts for cutting boards etc.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#608 |
From discussions within this forum, I gather that damping felt should be soft. I am looking at post #65
Frugel-Horn Mk3 flat-paks McMaster has 8845K253 which is F26. Check it out at McMaster-Carr or McMaster-Carr and enter 8845K253. |
#609 |
Sorry, my post #608 was a question. Will that felt work or should it be denser?
#610 |
frugal-phile(tm)
Lokely domething between the Soft & UltraSoft would be suitable, without some in my hand i couldn't tell you which would be most suitable.
I could mail out some traveling samples Given what the stuff costs from McMaster you might as well just buy the UltraTouch cotton felt from Bob @ CSS ($10 for a 12" x 47.5" chunk... good for FH3 & a couple other projects. dave
| Frugel-Horn Mk3 flat-paks | planet10 | Planet 10 hifi | 389 | 13th May 2013 08:38 PM |
| Frugel-Horn Mk3 | planet10 | Full Range | 1002 | 30th April 2013 04:52 PM |
| Frugel-Horn Mk3 Auditions | planet10 | Full Range | 24 | 8th June 2012 07:18 PM |
| "straight" frugel horn mk3 | mahleriana | Full Range | 10 | 15th April 2011 01:28 AM |
| My Frugel-Horn Build | italynstylion | Full Range | 130 | 22nd June 2010 12:24 AM |
