Old 6th January 2012, 04:46 PM   #581
frugal-phile(tm)
planet10's Avatar
Coaxman,
Where are you in Canada?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th February 2012, 02:03 AM   #582
Jdot is offline Jdot  Australia
Jdot's Avatar
Send a message via MSN to Jdot
I've had my pair going for a few months now so it's about time I posted some pics and feedback.
Although I did all the stuffing as per instructions and post #424, with the removable lid I ended up taking all stuffing from the front chamber so it's left looking like my first pic here. I dont find it's too boomy at all, the bass now matches the mid/highs just nicely. In saying that, they are not in the perfect listening position just now. I'll soon be moving them to my back room where they'll be sitting a good distance from the wall and nicely in a corner. This may require some stuffing placed back in, but thats why I made the top removable hay
I'd recommend the method I used for the top lid removal. One M6 bolt into a self tapping timber thread insert. You need to do a bit of sanding till the lid fits snugly, but then it's access in seconds. I used self adhesive foam strip designed for door draft sealing to form a gasket. If you glue a "gate" of stuffing across the base you can just drop in or remove stuffing quickly and easily (you do need to remove the driver first of course).
I was going to make some feet coming out for the floor spikes but ran out of time. They're very steady with them just fixed to the four corners how it is.
I spent a lot of time modifying the original dxf for use with 18mm ply that retains all internal dimensions as drawn. It’s for a cnc router but could be used for hand cutting too. If anyone would like a copy just pm me.
Thanks heaps to the developers of these little beauties, both for the design and knowledge plus all the "after sale service". I spend more time listening to them now than my Sonus Fabers.
Old 5th February 2012, 05:29 AM   #583
Jodt, how do they compare with your Sonus Fabers? Strengths and weaknesses? And which Sonus Fabers do you have?
Thanks,
UL
Old 5th February 2012, 07:28 PM   #584
chrisb is offline chrisb  Canada
Jdot - brilliant work - the last line of post 582 is very telling
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 5th February 2012, 09:28 PM   #585
TerryO is offline TerryO  United States
TerryO's Avatar
I certainly agree.
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 17th February 2012, 07:02 AM   #586
frugal-phile(tm)
planet10's Avatar
Another centre -- for those with CHR FH3.
http://homepage.mac.com/tlinespeaker...tre-160212.pdf
dave
Old 17th February 2012, 08:08 AM   #587
Has anyone tried to build this with the Fe166En 160mm driver?
Presumably the horn length would have to be scaled up to the 1/4 wave length for its Fs... but other than that.. the basic design should hold, no?
Old 17th February 2012, 09:00 AM   #588
frugal-phile(tm)
planet10's Avatar
We have not successfully made this idea work for the FE166.
dave
Old 17th February 2012, 04:30 PM   #589
Thanks Planet10. Now I just have to decide if I'll build based on the 126 or if I'll do some measurements and start to experiment.
Old 17th February 2012, 06:47 PM   #590
do you already have the FE166E on hand, or in transit?
if so a BIB would likely be the simplest - for which I'm sure the math has been done; for a more advanced build and arguably more nuanced performance, the Woden Victor or Olson / Nagaoka manifold (Haruna) would be worth a look
based on several builds of similar designs, I'd imagine the former would be an easier build (if my part count is right, there's 38 pieces per box for the manifolds)
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 284 22nd May 2012 05:08 AM
Frugel-Horn Mk3 planet10 Full Range 846 23rd April 2012 08:59 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 16 12th March 2012 09:11 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Page generated in 0.11571 seconds (79.53% PHP - 20.47% MySQL) with 11 queries
