Old 10th November 2011, 04:22 PM   #531
chrisb is offline chrisb  Canada
Originally Posted by mythosofsmythos View Post
hi all - I'm about to start building a pair of frugal horns and my question is where/how to place the terminals? Also, do terminals typically come with the drivers when you buy them? I'm planning to order Fostex FE126En.
I presume I need to resolve these questions before I start gluing my panels together as I'll need to cut a space at the back for the terminals prior to assembly. (The Fostex website gives a nice schematic of the driver so I'm happy proceeding with the front of the cabinet before the speakers arrive.)
Appreciate your thoughts.
The location of terminals was intentionally left off the design drawings to allow flexibility
I personally like to keep the internal wire routing as short as possible, and mount mine on the rear slanted panel approx 75mm from the top.
In line with the "frugal" philosophy, there are several very inexpensive types of binding post / terminal cups or blocks that can be mounted externally, I like using a 2" cup with 5 way binding posts as it recesses on enclosures' rear panels, and also allows a bit of a hand-hold.
If you're ordering drivers from major distributors (Madiosound, PartsExpress, etc) terminals wouldn't be included, but can certainly ordered separately. I wouldn't spend more than $3-4 per enclosure for terminals.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 10th November 2011, 04:27 PM   #532
Originally Posted by jonparkhurst View Post
If you were to put on a supra baffle to expand the outer edges and install an 8 inch driver in it???? What would happen....would it conflict with the back of the actual 5 inch opening going in to the frugal, would it totally suck?
I am finishing up my second set of frugals and thought about how others are making supra baffles to accommodate other drivers.....
?What would theoretically happen to an 8 inch full range driver.....Feel free to flog me now or later......
Jon
whether /how well any particular 8" driver would "theoretically work" in this design is hard to say, but it is likely that the fit would be very tight - at the very least might require another spacer between the enclosure front panel and supra-baffle
Old 10th November 2011, 07:12 PM   #533
thanks!! will let you know how i get on.
Old 10th November 2011, 10:18 PM   #534
Originally Posted by woodturner-fran View Post
A friend has some jordan JX92s - he is willing to give me a lend of them to try out, but its a bit of a job to go and actually get them (distance).
Can anyone tell me whether they are suited to the frugal horn? spec sheet here: http://documents.jordan-usa.com/JX92S.pdf
TIA
fran
Anyone know an answer to this?
Fran
Old 10th November 2011, 10:57 PM   #535
frugal-phile(tm)
planet10's Avatar
If you can fit them, maybe. and if you can make JX92s work, you are likely able to make A10.2 work. The closest -- size wise -- we have done is FE138eSR and it worked well except where it fell on its face from issues not influenced by the FH3. Used as a bass driver in a FAST with FF85wk, very good.
Try JX92 and report back.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th November 2011, 11:44 PM   #536
They're only 140mmdia, so should fit in OK I think, don't think they'd go back too far...
will report back....
Old 11th November 2011, 11:22 AM   #537
I mounted these terminals, which require only a small opening, 12 inches from the top. That distance still allows access to wiring after the cabs are glued up. They also look good at that location.
Gold Plated Banana 5-Way Speaker Terminal 260-302
Old 11th November 2011, 10:22 PM   #538
frugal-phile(tm)
planet10's Avatar
Thanx for the URL, i'd been looking for those on PE site (and not finding them) for some time. We use a 2" cup with the same posts (preferred over the solid metal ones)
dave
Old 11th November 2011, 10:52 PM   #539
skeeter99's Avatar
dave
I've used those ones too on a couple builds and they are great and inexpensive
Scott
Old 17th November 2011, 10:51 AM   #540
What type of wire do you use to connect the driver to the terminal? - thanx
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 389 13th May 2013 08:38 PM
Frugel-Horn Mk3 planet10 Full Range 1002 30th April 2013 04:52 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright ©1999-2013 diyAudio
