#511 |
OK, now I'm cooked. I've been following this thread on and off for a while and figured this would be my next build. I just bought a used pair of 126e drivers for not much money (check the swap meet board and you'll see it). I'm looking to use leftover material from prior projects if it is not in bad condition, but I'll spring for a 4x8 sheet if I have to. I have more tools than I did the last time I built speakers about 6-7 years ago (Proac 2.5 clones). I also have a digital camera now, in fact I've gone through a bunch, so I'll take pictures this time as I go. (7 years ago digital cameras were not yet ubiquitous).
#512 |
#513 |
i built my first pair with CHP70, but i will make another pair with Alpair 7. i asked Mark when and where to get the gen3 driver in germany (or elsewhere in europe), so he said end of december in this strassacker shop. thats ok with me, but how much difference will there be between the gen 1 and gen 3 versions? only difference in damping?
#514 |
I am thinking about building the MkIII, but I have been bitten by the OB bug
So before I start, I would like to get some opinions - how the does the sound FH MkIII compare with OB designs, I think I have read somewhere that the FHs are as close as one can get to open baffle using a "box" design approach...Thanks, Jaz |
#515 | |
I've seen the Mk III, but would be interested in which Open Baffle speaker get's close to it sonically. The problem is that there are a lot of OB designs out there, but in the end the sonic signature is very room dependant. Like any other design, OB's are a compromise (actually a lot of compromises) and what suits one room may not work well in another. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#516 | |
Understood, I was just trying to get a sense if the MkIII would be able to provide the "open" or "no-box" characteristics that the OB designs are commonly known for, say in the same room. Again, just seeking opinions, as there can be no definitive answer given all the variables involved as you have rightfully pointed out. Jaz |
#517 |
frugal-phile(tm)
It comes down to execution. One of the "boxiest speakers i have ever heard was an OB Iris 15".
Do a good build of the FH3 (using good mulyiply or better) and they do a really good job of disappearing The way they energize the room will be different. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#518 |
I made mine some time ago and have been listening now for a few months, previously to some Needles which I thought were very good. The FH3 is in a class of it's own, I've said this before and I can hear the groans but some people are new and may not have heard it.
A brilliant and beautiful design plus the MA drivers go together to make something that is far more than the sum of it's parts. One of those happy accidents that humans occasionally create. Jim |
#519 |
When you say "multiply or better" does that mean I can use solid wood for construction of the cabinet? Thanks
#520 |
My primary system consists OB Tang Band W8-1808s over H-frame Alphas. I enjoy my FH3s in a secondary bedroom system.
| Frugel-Horn Mk3 flat-paks | planet10 | Planet 10 hifi | 389 | 13th May 2013 08:38 PM |
| Frugel-Horn Mk3 | planet10 | Full Range | 1002 | 30th April 2013 04:52 PM |
| Frugel-Horn Mk3 Auditions | planet10 | Full Range | 24 | 8th June 2012 07:18 PM |
| "straight" frugel horn mk3 | mahleriana | Full Range | 10 | 15th April 2011 01:28 AM |
| My Frugel-Horn Build | italynstylion | Full Range | 130 | 22nd June 2010 12:24 AM |
