Old 12th July 2011, 01:39 PM   #391
Bob Brines's Avatar
Originally Posted by planet10 View Post
Alpair 7s are not a hardship.
+1. Mine are not in FH's, but it is simply amazing what comes out of these little guys.
Bob
Old 12th July 2011, 01:41 PM   #392
Munga is offline Munga  Australia
Bob
I can't wait!
Old 12th July 2011, 02:25 PM   #393
jemraid is offline jemraid  United Kingdom
I have said something like this before, but not in this thread;
The FH3's and in my case the CHP-70's are a culmination of excellent design by dedicated enthusiasts. Just occasionally something occurs that takes a design out of the ordinary into the extraordinary. This combination of a simple and elegant cabinet coupled with a drive unit designed with DIY in mind becomes something far more than the sum of its parts.
One of those happy accidents that illuminates our lives with so much pleasure.
Jim
Old 13th July 2011, 10:10 PM   #394
I know this is a bit of a cheeky question , so I apologise in advance.
I'm planning on building these and at least trying my FE127en in them. But a buddy of mine is also going to do a pair and he needs to buy drivers.
So my question is: What are the best drivers?
I ask because there are a bunch of options, I can go with him on shipping and buy a set as well .... etc etc
TIA,
Fran
Old 13th July 2011, 10:18 PM   #395
frugal-phile(tm)
planet10's Avatar
You will get different opinions based on people's tastes & amplifiers. My personal favorite is the Alpair7eN. Chris (and those with flea watt amps) like the FE126eN. Our local opinions are based on EnABLed drivers.
If he is rocker, i'd suggest EL70. If he has an amp that he wouldn't really like to hear have all its warts exposed then EL70 or CHP70. No one has heard the new CHR70 but it is also a candidate.
Of the other drivers that we know work fine (FE108, TB W5-1611, more) i have no opinion not having heard them.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th July 2011, 10:33 PM   #396
He has varied taste, not just rock but bits of everything. He's using a cary 300b amp so he has some watts - prob 7-10W or so.
OK so it looks like alpair 7 so, and I have my fe127en to try....
Thanks,
Fran
Old 14th July 2011, 04:48 AM   #397
chrisb is offline chrisb  Canada
Fran - I played with a few drivers in a pair of test mule FH3s a few weeks back, including:
FE126En (EnABLed) - even stock, Fostex's latest version is great bang for the buck in this enclosure - certainly my favorite for in your face party/rocking (as long as you're partying at under 100dB)
FE127E (EnABLed) - definitely works well enough, but lacks the jump/snap of the 126
TB W5-1611 (stock) - my first listen to this driver - big surprise - very nice indeed
Alpair 7 (EnABled) - saving the best for last - not much else to say, other than that power below that of 300B (or in my case 6CA7 in triode mode) might not be enough for some folks. (well, and that I've yet to hear this driver sound less than glorious in any enclosure, and there's been more than a few)
It's been almost a year since I heard the EL70 or CHR70 in this enclosure, but I can recall preferring the FE126E at the time. In Dave's very large space the dynamics offered by the Fostex's higher sensitivity worked for me, although lacking corner reinforcement, they definitely suffered from thinner bottom end compared to the EL70 and Alpair7.
OTOH, Colin (Toppsy) and several other builders in the UK have been more than happy with CHP70 in their FH3.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 14th July 2011, 08:20 AM   #398
Seems like the alpair 7 is the way to go then..... and if I make some alternate front baffles I could try the FE127 as well.
Dave: would it be possible to get the dxf file for the FH3 - I'm assuming you're using a cnc machine? I understand completely if you don't want to give it out.
Fran
Old 14th July 2011, 01:40 PM   #399
Just had a look at madisound and it seems the alpair 7s are out of stock. Where can you buy 'em?
Fran
Old 14th July 2011, 02:35 PM   #400
Default Alpair7 availability
Fran
In response to a July 8th email inquiry, Madisound estimated they would be back in stock in 10 days....
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 403 Today 11:12 AM
Frugel-Horn Mk3 planet10 Full Range 1002 30th April 2013 04:52 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
