Frugel-Horn Mk3 Builds & Build Questions
Old 5th July 2011, 12:56 PM   #381
wingman03 is offline wingman03  United States
First time poster from Austin TX here, I've been lurking for awhile just trying to soak up all the knowlege I can. I'm a novice speaker builder but I have a fair amount of woodworking experience.
I'm in the middle of building a set of the Frugal 3's loaded with the 126en's. If i like they way they sound I'll build more so I've set up a jig for the sides; the nest set will be faster and easier for sure.
A quick question, would shifting the center line of the speakers down a half inch or so significantly affect them and would I need to lower the front of the baffle the same amount?
I'll post up some pictures anda few build comments when I'm down the road a bit. Thanks a again for all the info here, I hope I can contribute in some way in the future.
Old 5th July 2011, 01:01 PM   #382
On Hiatus
SY's Avatar
Welcome to the forum, Wingman. I have the opposite problem- my woodworking skills/equipment are something south of rudimentary, but have a lot of speaker design and measurement capability. Drop me a PM if you're interested in combining some skills- I'm in NE Austin.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th July 2011, 11:57 AM   #383
I'm up in the Lago Vista Area, I'll catch up with you at some point.
Still wondering what the effect of lowering the speaker some would be, if any.
Old 6th July 2011, 04:23 PM   #384
chrisb is offline chrisb
I'll post up some pictures and a few build comments when I'm down the road a bit. Thanks a again for all the info here, I hope I can contribute in some way in the future.
If you mean the horizontal center line ( driver height from floor), I'd doubt that lowering by 1/2" would have little effect on internal loading characteristics, and no other changes should be required. As referred to a couple of times, we made a set of mules with removable mounting plates to allow for quick testing of a range of drivers, some of which ( e.g. TB W5-1611) ended up with a different mounting height, with no apparent problems.
like my mind, this space intentionally blank
Old 6th July 2011, 05:40 PM   #385
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The Zd of the driver has been very specifically choosen to cancel the 1st objectionable harmonic, but a 1/2" shift will likely have only a small effect if any.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th July 2011, 04:06 PM   #386
Munga is offline Munga  Australia
Hi Guys,
Are there any frugel horn plans in the works for the alpair 10? I would be willing to pay if needs be!
Derek
Old 11th July 2011, 05:42 PM   #387
frugal-phile(tm)
planet10's Avatar
Larger drivers are proving to be a tough nut to crack.
dave
Old 12th July 2011, 03:01 AM   #388
thats a shame. Alpair 7's it will have to be then!
Old 12th July 2011, 03:41 AM   #389
frugal-phile(tm)
planet10's Avatar
Alpair 7s are not a hardship.
I prefer them myself.
dave
Old 12th July 2011, 05:59 AM   #390
In fact in a way it is a good thing. It makes the descision of what driver to use for me, and saves me money! Thanks guys.
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1624 12th June 2018 08:46 PM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 06:16 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
