Frugel-Horn Mk3 Builds & Build Questions
Old 25th June 2011, 10:17 AM   #371
Toppsy is offline Toppsy  United Kingdom
leeoh wrote
By the way, did you see the video, attached to one of the posts showing how to avoid splintering when ripping ply? The guy raised the blade slightly above table level so that when he put it thro', the blade scored a very shallow cut, then he put the blade to the proper height to cut right thro' the sheet. Makes sense.
I generally have all my 2440mm x 1220mm sheet MDF and Baltic Birch Ply cut on a CNC controlled flat bed circular saw and have no issues with rip out of the grain. Perhaps I'm fortunate. But if one is using a home DIY circular saw table that has a much slower cutting speed then yes this method may help. I think the secret is as fast a cutting speed as you can achieve and a sharp blade. Particle board will blunt a new blade very quickly and is why I don't use the stuff, cheap as it is.
Old 25th June 2011, 11:05 AM   #372
jimbro is offline jimbro  United States
I just use a zero-clearance insert with a Forrest blade and I have no splintering.
Old 25th June 2011, 04:43 PM   #373
chrisb is offline chrisb
Colin, most CNC panel or beam saws and even many larger commercial table saws will have a counter-rotating pre-scoring saw to prevents the type of chip-out on bottom edge. If the scoring blade is disabled, there's no guarantee on eliminating chipping across veneer grain patterns or on double sided melamine, plastic laminate layups - indeed the latter two can chip in any direction of cut .
The double cutting that leeoh mentioned achieves essentially the same results, albeit in a more time consuming manner, and unless material is feed with pressurized feed rollers, there's the risk of not perfect edges on the second cut..
I've found high density plywood can be t least as hard on tooling tooling edges as MDF - certainly router bits and hole saws get dull and burn much faster on Baltic Birch than on MDF or particle board / melamine .
like my mind, this space intentionally blank
Old 25th June 2011, 06:33 PM   #374
kec is offline kec  United States
kec's Avatar
I've used masking tape to prevent splintering. It's a hassle to do, but works pretty good.
MSI E350IS mITX > Foobar > SPDIF > Denon A7100 preamp > Crown XLS1000 > ?
Old 1st July 2011, 04:52 AM   #375
Ultralight is offline Ultralight  United States
Default No Rez for FH3 & others?
OK, it looks like the most are using polyfill and some type of thick cotton or wool felt for damping. Are those better or as good as the No Rez stuff that I've been reading about that is supposedly designed specifically for damping speakers? The claims sure look impressive.
Thanks for any help.
No Rez 24"x27" Sheet - NR-24x27
UL
Old 1st July 2011, 05:03 AM   #376
TerryO is offline TerryO  United States
TerryO's Avatar
UL
It looks to be a very expensive way to kill your speakers. I wouldn't bother with it, cotton, wool and polyfill all work well and don't take the life out of the music.
However, to be fair, there are those that believe that if a little damping is good, too much is even better.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 1st July 2011, 06:24 AM   #377
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
In the specific case of the FH3 we want volume fiill which this isn't. And it is far too thick to use anywhere else.
I have a whole bunch of that no-rez stuff here. Still haven't found a useful place for it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd July 2011, 09:38 PM   #378
TerryO's Avatar
dave
Dave,
I turned down a bunch of that stuff at one of the last meets in Surrey, BC.
One of a very limited number of smart moves I've ever made.
Best Regards,
Terry
Old 4th July 2011, 12:37 AM   #379
LOL!!! Thanks guys for the heads up on the NO REZ. And I thought I stumbled on some great secret to take the FH3 to another level.... Talk about being a newbie.
UL
Old 4th July 2011, 12:42 AM   #380
The 1/2" Ultratouch (recycled denim) is very ] easy to work with, and quite adequate for internal panels on the FH3.
For the additonal loose fill, Acoustastuff or generic BAF from sewing supply houses works very well. In the case of the FH, the front fold below the driver expands downwards, so some type of mesh is advisable to hold in place.
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1624 12th June 2018 08:46 PM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 06:16 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
