Frugel-Horn Mk3 Builds & Build Questions - Page 33 - diyAudio
Old 11th May 2011, 11:08 PM   #321
jemraid is offline jemraid  United Kingdom
Originally Posted by planet10 View Post
Something the designers are strongly discouraging.
dave
That was the bit I meant Dave.
Jim
FH3 build using very simple tools and a point to point Gain Clone with largish power supply. http://www.jasread.com/fh3/index.html
Old 11th May 2011, 11:28 PM   #322
frugal-phile(tm)
planet10's Avatar
The designers are strongly discouraging the use of MDF in any FH3 flat-paks. And none of the 3 in process are using it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th May 2011, 08:20 AM   #323
coley is offline coley  Australia
what plywoods are people using then. and what difference are people finding. Thanks
Old 12th May 2011, 08:44 AM   #324
frugal-phile(tm)
planet10's Avatar
We typically use utility grade baltic birch. For higher end bilds we have been using bamboo plywood (the stranded variety being the best).We have yet to do a build that has required us to use the premium grade architectural plywoods.
Better downward dynamic range, better imaging/soundstage, less boxy speakers, and the ability of the speaker to become harder to locate (the ability to dissappear). Box design, shape, and other details play a interdependent role.
dave
Old 12th May 2011, 09:58 AM   #325
As you can i see i live in oz and finding it hard to find Baltic birch. I have found structural ply, marine aa grade and loads of mdf. reading other forums people here have struggled too. is using marine ply better than mdf? any help would be great.
Old 12th May 2011, 12:09 PM   #326
THORNSPAWN's Avatar
I use Hoop Pine for the Aussie Flat Packs
Old 12th May 2011, 07:32 PM   #327
frugal-phile(tm)
planet10's Avatar
Off-topic posts have been moved to a more appropriate thread.
dave
Old 14th May 2011, 04:03 AM   #328
zman01 is online now zman01  Bangladesh
Originally Posted by platplaas View Post
I haven't had the good fortune of hearing the FH MK3s, I'm tempted to maybe build a set this summer, but I'm also thinking about waiting for the big brother version to the finalized. (166en)
Is there a new FH really getting designed for the 166en?
-Zia
Old 14th May 2011, 04:15 AM   #329
frugal-phile(tm)
planet10's Avatar
Sort of.
dave
Old 14th May 2011, 08:39 AM   #330
I have started to make my MK3. As a boilermaker i see this a lot in drawings, Why don't the draftsmen put in a dimension instead of an angle. only 1 min extra work for the draftsmen that results in an easier and more correct build. Also the drawing would be easier to read if it had correct hidden detail on the baffle. I have to say that the info on marking the radius is good work!! Also Have to say a thanks to everyone who has contributed to the design on the speakers.
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 512 18th January 2017 11:56 PM
Frugel-Horn Mk3 planet10 Full Range 1551 29th November 2016 05:50 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 08:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 02:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 01:24 AM
Copyright 1999-2017 diyAudio
