Frugel-Horn Mk3 Builds & Build Questions
Old 27th April 2011, 11:14 PM   #291
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
C'mon Chris, give us a hint then.
jeff
Old 28th April 2011, 08:08 AM   #292
chrisb is offline chrisb
jeff
google is your friend
agent provocateur
kinda burnt out - taking a break
Old 29th April 2011, 05:20 AM   #293
mugdecoffee is offline mugdecoffee  United States
So how have people been tweaking the damping after building their speakers? Is it possible to adjust the stuffing through the speaker's hole or is it best to leave a panel unglued? Do you just guess and hope it sounds good when its glued up?
Old 29th April 2011, 12:34 PM   #294
Poultrygeist is offline Poultrygeist  United States
I followed the original damping plan for the FE126En and weighed the acoustistuff to get the recommended amount in the "V". If you tease the acoustistuff too much it's hard to achieve the recommended weight in the "V". One bag from Parts Express was almost enough to do the four horns that I built. It's possible to adjust some of the acoustistuff through the hole after final assembly but only what you can reach. You're not going to get a hand deep into the "V" once the sides are glued.
I found a challenging part of the damping plan was gluing the felt to the driver compartment so all sides matched up and were covered uniformly after assembly. Lots of "figuring" before I found the right spots to glue the felt on the single board sides.
After buttoning everything up the sound is so good I haven't any desire to tweak anything at this time.
Old 1st May 2011, 11:51 AM   #295
chalkandtalk is offline chalkandtalk  United Kingdom
I'd just like thank all those who have contributed to this project. I have built a pair of Frugal horn mk3 with Fostex 126En. They have about 20 hours use now and are sounding truly superb. They are much clearer than my previous speakers (3500) - no question. So thanks everyone
All that remains to do is to finish the cabinets., and experiment a bit with stuffing and placement.
Old 1st May 2011, 02:39 PM   #296
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
You're welcome. Glad you like them.
Old 1st May 2011, 06:13 PM   #297
parkerfly is offline parkerfly  United States
hello everyone, been following the thread and was wondering if there was anyone out there that could build these for me or cut the pieces out? My wood working skills are not very good and my last build( sachiko's fe206en) was great but looks very DIY. I already have some fostex 126e's and think this would be a great speaker. PM if possible or direct me to where i need to go, thanks.
Beau S.
in Texas
Old 1st May 2011, 06:39 PM   #298
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3 flat-paks
As time goes on i hope to see more flat-pak manufacturers. Guys in the UK & Australia are gearing up.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd May 2011, 04:22 AM   #299
paulwd is offline paulwd  Australia
It's been a few weeks, but I have finally finished them. I used a small microfibre roller for the high gloss enamel paint and it worked a treat!
Overall, I couldn't be happier with the way these have worked out. Now I can sit back and enjoy the sound.
Old 2nd May 2011, 04:38 AM   #300
skeeter99 is offline skeeter99  United States
skeeter99's Avatar
Originally Posted by paulwd View Post
It's been a few weeks, but I have finally finished them. I used a small microfibre roller for the high gloss enamel paint and it worked a treat! ...
Those look fantastic!! Nicely done
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 07:16 PM
Frugel-Horn Mk3 planet10 Full Range 1602 2nd October 2017 08:18 AM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 08:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 02:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 01:24 AM
