Frugel-Horn Mk3 Builds & Build Questions - Page 26 - diyAudio
Old 1st April 2011, 12:59 PM   #251
jemraid is offline jemraid  United Kingdom
Dear Poultrygeist,
If you do make the FH3/CHP-70/Dared combination please do let us know what you think, I'm very keen to read what you think.
Regards - Jim
FH3 build using very simple tools and a point to point Gain Clone with largish power supply. http://www.jasread.com/fh3/index.html
Old 1st April 2011, 02:15 PM   #252
triode_al's Avatar
I have seen, scrolling through these pages, a lot of 'hard edged' enclosures.
This will give diffraction. Specifically as the enclosures get smaller.
Like is said in the "Fonken" website;
My favourite page in Olson's Acoustics is the one with the graphs that show the affect of box shape on diffraction and from this that a box with heavily champhered edges gets you most of the way with little effort.
The sound will clean up if BOTH the inside of the baffle and the outside edges of the enclosure are beveled, that is you just take a router with a 1/2 inch curve and just blast it off. It gives a lot more sound stage.
albert
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 1st April 2011, 10:12 PM   #253
frugal-phile(tm)
planet10's Avatar
Posted earlier.
http://www.diyaudio.com/forums/full-...ml#post2359824
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd April 2011, 08:00 AM   #254
triode_al's Avatar
Hi Dave,
indeed, I see now. I like the implementation of http://www.diyaudio.com/forums/full-...ml#post2365327.
I see a small angled curve is covered too.
Just a question though, has a rounded or beveled edge on de inside been considered?
In FH Mk3 beta document 25-oct-10 this is not shown.
On my Fostex 103 horn this was very important, it cleared up the sound. But that speaker is very shallow I admit.
albert
Old 2nd April 2011, 08:30 AM   #255
frugal-phile(tm)
planet10's Avatar
Originally Posted by triode_al View Post
...has a rounded or beveled edge on de inside been considered?
It is a given. Driver cutouts are depicted as in the drawing snapshot attached and item 5 in the notes is standard boilerplate. Thanx for pointing out that it is missing. I really need to find some time to add to the drawings.
dave
Old 2nd April 2011, 09:21 AM   #256
Default Back chamfer
Dear Triode-al and Dave
I used a little round rasp on the inside of my baffles and finished the chamfer off with some really coarse sand paper;
Outside on a windy day and wearing a mask!
I am running mine in now, using Daves trick of a tuner played very quietly through them for a week or so, but do have the occasional sneaky listen for 5 mins or so. I only listen at low volume and they seem to need less power each time I do and as for the sound well, every time it gets so much better.
Warmest wishes - Jim
Old 2nd April 2011, 09:43 AM   #257
frugal-phile(tm)
planet10's Avatar
I've used that method before -- usually after the baffle has been attached already (because it is a retrofit )
dave
Old 2nd April 2011, 12:15 PM   #258
triode_al's Avatar
Originally Posted by planet10 View Post
. . .I really need to find some time to add to the drawings.
dave
Dave, Thanks,
and for Jim: I seem to notice also in the photo of your enclosures that you have 90 degrees angles (bottom left) .
The sharp edges gives audible intermodulation distortion. The three sides next to the speaker really need smoothing/rounding.
albert
Old 2nd April 2011, 12:24 PM   #259
Dear Al,
Mine are still running in and I haven't got the front [false] baffle on yet. They do sound fine though with good stereo instrument postioning. I'll wait awhile and see what others say, once done cannot be altered.
Old 6th April 2011, 04:00 AM   #260
Default Helder or HifiMeDiy for 4 Ohms
Hi Jemraid,
I'd like to heartily agree with Kristliefur's recommendation about the Helder or HiFiMeDiy T3 boards for driving 4 ohms. Also to recommend the Virtue amps if your budget can afford them.
These examples of good Tripath implementations sound very close to a combination of really good tube SET coupled with the drive and control of monster solid-state amps. It's best described as "lively, juicy and powerfully extended with finesse AND slam"
I use this type of amp to drive the bass section my HolisticAudio H3's which run at about 3 Ohms, and the levels they attain are stunningly loud... and clean.
Just look for the Helder 2050MkII or the HifiMeDIY T3..... also Sure Electronics is selling similar units through Parts Express...
It won't cost you much to Try a pair and put your concerns to rest!
All the Best!
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 519 22nd April 2017 09:33 PM
Frugel-Horn Mk3 planet10 Full Range 1583 7th March 2017 10:34 AM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright 1999-2017 diyAudio
