Frugel-Horn Mk3 Builds & Build Questions - Page 20 - diyAudio
Old 10th March 2011, 08:51 AM   #191
paulwd is offline paulwd  Australia
Yeah, I wanted to rebate them when I was building, but I used 15mm ply and I thought it might be too thin.
I reckon I will add a 9mm panel to the front.......like you say, will help the sound as well as being a feature! Thanks for the tip.
Old 12th March 2011, 07:58 AM   #192
GdK is offline GdK  Netherlands
Hello all,
I recently did the same thing.
I started the Mk3's (15mm) with the FE126En's, but changed to the A7's.
I glued a 9mm panel to the front.
Next up is the veneer, my wife will choose the color....
Thanks for the wonderful design and tips!
Old 12th March 2011, 11:31 AM   #193
GdK, they are looking good!
I'm looking at finishing mine in a gloss white / antique white. Also managed to source some 9mm marine ply for the front
Old 12th March 2011, 02:46 PM   #194
Squeak is offline Squeak  Denmark
Squeak's Avatar
Could someone explain what the advantage of putting the resonating part of the pipe behind the driver, instead of underneath it? I know the driver wouldn't fit as it is now, but that is a design choise.
It used to be common in these types of designs to have the closed part on the driver side, under it or covering it.
It seems it would force the sound to interact with the cavity and damp out highs and mids better, with no direct path to the mouth of the horn/resonator.
Does this setup have better efficiency?
Old 12th March 2011, 03:34 PM   #195
Scottmoose's Avatar
Indeed they do.
Sounds like a plan. Here's another pair that have been done with that finish, albeit with a solid ash front baffle: Frugel-Horn Mk3
Old 12th March 2011, 03:48 PM   #196
Any developments on a 6" speaker model?
Old 12th March 2011, 04:27 PM   #197
Squeak's Avatar
Originally Posted by Squeak View Post
Could someone explain what the advantage of putting the resonating part of the pipe behind the driver, instead of underneath it? I know the driver wouldn't fit as it is now, but that is a design choice.
Yeah I know the whole line is resonating, let me just be causious and say the pointed, closed end.
Old 12th March 2011, 04:33 PM   #198
Scottmoose's Avatar
In the works, although when, where & how it will be released have yet to be determined.
Old 12th March 2011, 04:40 PM   #199
Great - Is this the right thread to listen for updates on the 6" model? Thanks.
Old 12th March 2011, 05:25 PM   #200
jemraid is offline jemraid  United Kingdom
Hi all,
I am posting this picture to show that having loads of power tools and cutting benches etc is not absolutely necessary. I believe that this Do It Yourself audio pastime should be available to anyone with sufficient interest and that people who are bit nervous about starting a speaker building project should be encouraged to do so. If as a result of this one other person decides to make a pair then I will be very happy
These are the tools I will be using to make my FH3's, my one concession to power is a 30 yr old jigsaw and for this project I have lashed out 2.99 for an angle thingy, the one in the middle with the orange handle.
I am not and never have been a woodworker, I have made a few speakers and can use what I have learned from that to make these. What I have got is time and patience, patience to cut slowly and squarely, to plane the angles with my old Record plane and to practice first.
I have drawn the plan on all four sides, the tools are on one and you can see another resting against the window sill. My next task is to cut the front angles and the curves in the sides.
It's getting very enjoyable :-)
Warmest wishes - Jim
FH3 build using very simple tools and a point to point Gain Clone with largish power supply. http://www.jasread.com/fh3/index.html
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 522 5th June 2017 04:10 PM
Frugel-Horn Mk3 planet10 Full Range 1583 7th March 2017 10:34 AM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright 1999-2017 diyAudio
