Frugel-Horn Mk3 Builds & Build Questions - Page 2 - diyAudio
Old 3rd September 2010, 05:05 PM   #11
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
I was afraid you'd ask that - sorry, no.
Guess we'll have to fish it all out and weight it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd September 2010, 05:10 PM   #12
chrisb is offline chrisb  Canada
Originally Posted by PDRCanada View Post
I think the side grid drawing are not needed...
The 69"radius is smaller than I had first thought from looking at the photos.
A swing arm jig to my router would make the panels easy to cut, the rest of the build is very easy. A DIY dream.
Thanks for all you guys do.......
Since the chord/segment sketch was intended for manual lay-out of (template for) hand-machined (as opposed to CNC) side panels, I wonder if it should also include dimensions for layout of angled front, as per:
on hiatus
Old 3rd September 2010, 06:19 PM   #13
Godzilla's Avatar
>>> only a really crazy person would be routinely swapping drivers just for the fun of it...
LOL!
Old 6th September 2010, 08:58 PM   #14
wagtail is offline wagtail  Ireland
wagtail's Avatar
hi,
i am redrawing the plans for the nominal 18mm ply ( actual 17.4mm) that i have but having problems replicating the 021910 doc internal dimensions, has anyone else tried drawing it? are the baffle and the back parallel ?
Old 6th September 2010, 10:10 PM   #15
frugal-phile(tm)
planet10's Avatar
Here is the 18mm plan. Hopefully it will give some clues to convert to 17.4mm.
Conversion to a larger material than the ref 15mm requires moving back the back panel by the extra thickness, raising the height of the point the same (because this is the extra thickness of the divider, length of horn remains the same to the choke point), and using a half-round to define the choke (or an approximation). Then all the outer panels increase into the outside, and the divider panel towards the back.
The front and the back are not parallel.
dave
Old 6th September 2010, 11:23 PM   #16
wagtail's Avatar
thanks dave,
it's after midnight here, another another glass of red and then to bed, will work on it tomorrow.
simon
Old 18th September 2010, 11:38 AM   #17
wagtail's Avatar
what is the best position for the speaker connections?
Simon
Old 18th September 2010, 12:12 PM   #18
Scottmoose's Avatar
Wherever you like. We wouldn't be so bold as to tell people where to stick them.
Old 18th September 2010, 03:14 PM   #19
wagtail's Avatar
We?
Old 18th September 2010, 04:31 PM   #20
Scottmoose's Avatar
Dave, Chris and myself (i.e. the people who designed it).
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 519 22nd April 2017 09:33 PM
Frugel-Horn Mk3 planet10 Full Range 1583 7th March 2017 10:34 AM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright 1999-2017 diyAudio
