Frugel-Horn Mk3 Builds & Build Questions
Old 29th November 2017, 08:29 PM   #1301
kwolff67 is offline kwolff67  United States
Thanks, Dave. I was wondering why the Stealth wasn't talked about as much these days seeing as it was such a cool concept. I didn't realize it was dependent on a particular driver that was no longer made. I will write to CSS.
Chris, when you write multiples, you mean doubling up the 4inch peerless? Do they need to be crossed over or just wired together? Is there a thread on this? It might be beyond my current skill set. I have zero experience with building crossovers as of yet.
Also, I just want to say that you guys did a great job with the FH3. I just got mine back up and running after being without them for a little over 2 years due to moving around and losing my power amp. It's like listening for the first time again. I really missed them. Thanks again.
Old 29th November 2017, 09:39 PM   #1302
chrisb is offline chrisb
Regarding multiples - the several builds in which we've used multiples (either 2 or 4 per side), they'd have been wired in parallel or series/parallel to keep net impedance within safe operating range of amps, and our general approach was to use passive line level XO, and bi-amp, so yes they'd be low passed. IIRC, the particular driver we used was the Peerless 830870, and in all cases I can remember, the enclosures were vented - either fairly compact MLTL, or the rather more cumbersome "Facets". - Word to the wise - when Dave says, "I've got this idea for an enclosure, but I'm having trouble figuring out how to draw it" be wary of taking the challenge of building a pair
like my mind, this space intentionally blank
Old 29th November 2017, 10:05 PM   #1303
So I could just put 2 per side (8 total. it's a small room) and vent the enclosure at the bottom of each side and leave the backs unvented. Sounds like it might be worth looking into, and I want to learn about crossovers at some point anyway.
Thanks.
Old 29th November 2017, 10:28 PM   #1304
My "per side" reference above should have read "per channel"- in the case of the Facets shown in above photo before being re-populated with drivers after Bernie's cladding of raw plywood boxes, you can see a total of 2 drivers per side of each enclosure, for a total of 8 in the stereo pair. Developed an amazing amount of LF for such a tiny driver. The front driver in this case was FF85WK.
The system was intended for biamping -crossed over somewhere in the 300Hz range, IIRC via PLLXO - although absolutely no reason why something like minidsp couldn't work as well - some might opine better? .
Old 30th November 2017, 03:18 AM   #1305
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by planet10 View Post
StealthWoofer plans:
Hang tough, i am working on plan updates. And actually checking what we built.
The plans have about 20 litres gross internal volume but are based on a 75° isoceles triangle, we may have built a 90° one. Turns out 90° has less volume than the same width smaller angle.
It is also the case that it has a height designed for the FH1.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th November 2017, 03:37 AM   #1306
frugal-phile(tm)
planet10's Avatar
The facets are an ML-Voigt, under the uFonkenSET in an ML-TL.
The 830870 ML-TL is a little shorted than the FH3, and less cross-section volume than the 75° stealthWoofer i posted earlier. With only a slight volume increase you could use 4.
For that same slight size increase you could use 2 Silver Flute W14 ML-TL we use in Tysen V2. The line is close to the FH3 height but still a tad shorter. The big advantage is that the SF is less than ˝ the price of the Peerless.
Both reach an estimated 35 Hz F10 almost as low as the single SDX7. The sealed SDX7 is more ameniable to EQ and will easily reach 25 with a small boost.
dave
Old 30th November 2017, 11:11 PM   #1307
stevodude is offline stevodude  Australia
Send a message via Yahoo to stevodude
Default fe206en
Hi everyone,
Long time since being on here, and a lot has happened, lost my house to Mainroads for a bypass road, boo, got divorced, mixed feelings about that one, moved into a new place, yah
I can finally setup as many bad *** speakers as I want, double Yah!
I am still wanting to build some big *** Frugel horns for my fe206en's.
Looks like the Sachiko spawn might be the go.
The plan I downloaded is dated 23-march-2007
1. Is this the latest version?
2. Where the heck can I get some hardwood Birch/void free plywood in Mackay, Queensland, as there is no hardware depo that caries category AB or AC?
3. The other option is to build them out of MDF and laminate, but would prefer plywood.
Cheers, S.
Old 30th November 2017, 11:26 PM   #1308
frugal-phile(tm)
planet10's Avatar
Originally Posted by stevodude View Post
Sachiko… 1. Is this the latest version?
Superceded by Kirishima.
Even better is Vulcan.
Plywood availability seems to be a bit spotty in Oz. Hoop pine ply seems to be avialble in some places, and the bamboo ply distributor in Tasmania makes me jealous — the good stuff is heavy enuff that shipping may be more than the actual ply thou.
dave
Old 1st December 2017, 05:26 PM   #1309
I've built / heard probably over a dozen models of Scott's large dual mouth designs, and if you can afford the required footprint (i.e. space behind the enclosures) - perhaps one of the positives of your new "life situation", would always recommend the rear mouth variants.
Old 6th December 2017, 11:13 AM   #1310
MatthewvB is offline MatthewvB  Netherlands
Hi there. First time posting here. Already learned tons about the DIY full range world and the FH3 seems to be a great first project.
I already cut birch plywood of 15mm, but for the front plate I don't have 18mm birch yet. I do however have solid oak flooring (18mm) leftovers. But I was wondering if the grooves on the bottom could be a downside? Would that alter the sound much?
Thanks,
http://www.fineoakflooring.co.uk/wp-...ing-bottom.jpg
Matthijs
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1673 5th August 2018 09:02 PM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 550 16th July 2018 04:45 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
