Frugel-Horn Mk3 Builds & Build Questions - Page 128 - diyAudio
Old 18th March 2017, 11:48 AM   #1271
Maybe try a Bafflle step compensation something Ike 1.5mh inductor and 3R resistor on your positive wire. That wil bring that bright rising top down quiet a bit and further fatten up the Bass.
Originally Posted by garym999 View Post
Sooo... more hours on the Alpairs and a A Pi with Allo Boss DAC and it is getting there. I,m liking the bass control and low end but high mids are to shrill. Can listen to it for a while and then I find I'm reaching for the volume control to turn it down. How best to tame this?
Old 6th April 2017, 12:17 AM   #1272
frugal-phile(tm)
planet10's Avatar
Originally Posted by Joca View Post
Question to the fostex 126en builds. How much dampening do you use in the front?
Typically none so as to extract maximum bass.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th April 2017, 01:04 AM   #1273
For Frugal horn build how to put stuffing below the speaker driver? do we need to put any mesh like net for holding the stuffing in place or how do we put stuffing below the driver?
Old 29th April 2017, 10:08 AM   #1274
zman01 is offline zman01  Bangladesh
sarathssca,
The mesh helps hold the poly-fill better. It is possible that the poly-fill itself might stay in place on its own, as it is light and fluffy, and has friction against the cabinet walls; the mesh gives more assurance that it won't fall down.
Old 29th April 2017, 10:29 AM   #1275
I created a suspension wire using eyes and then placed the thinest layer of sheet with a few spots of super glue to hold it in place. That stops the fill from getting lost.
__________________________________________________ ___________________________________
“There are only 10 types of people in the world: those who understand binary and those who don’t.”
Old 29th April 2017, 11:20 AM   #1276
garym999,
Nice work with the suspension, and I am assuming that the thin sheet is working for you. Personally I would be more comfortable with some thing with more holes in it vs the sheet you put in place. In your case, probably a few more criss-crosses of the string over the eyelets would have been enough also to keep the poly-fill in place (no sheet required).
Old 29th April 2017, 11:59 AM   #1277
The sheet is really thin. I did think about something a little more solid but I did not want any chance of any rattles after the event.
Old 29th April 2017, 01:51 PM   #1278
BackinBlack's Avatar
I used some "pea netting" stapled to the sides to form a basket for BAF fibre, but eventually replaced it with a rolled "tube" of Monacor wool fibre.
Always climbing mountains, well, large hills actually.
Old 29th April 2017, 10:00 PM   #1279
chuyler1's Avatar
I stapled a net of grill cloth.
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 519 22nd April 2017 09:33 PM
Frugel-Horn Mk3 planet10 Full Range 1583 7th March 2017 10:34 AM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright ©1999-2017 diyAudio
