Frugel-Horn Mk3 Builds & Build Questions
Joined 2022
Drone 7 ... Should have been more specific. No accessible AC that I can use use for tools other than apartment. Running a router, etc inside apartment is same as doing inside a house. I would get stoned.
Zene
Just a late thought ... Understand big ugly router is a no-go ... I was unclear on the jig-saw (price and blade wander were mentioned).
What about a Dremel?
Mounted on a stick of appropriate radius with a <=1/8" bit, two quick shallow swipes to frame/guide the cut on either side, then cut through with a coping saw and plane/sand at your leisure.
If the source of stoning is inside the apartment, engrave something nice first. If outside, answer the door with a hair dryer in your hand.
