Frugel-Horn Mk3 Builds & Build Questions
Old 23rd December 2010, 08:22 AM   #111
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
We are guessing that is will. I believe someone said they were going to do a test build.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd December 2010, 04:39 PM   #112
chrisb is offline chrisb
Originally Posted by kristleifur View Post
Went looking for plywood today ... Found smooth pure blond sheets of birch plywood, with two good sides per sheet. Wasn't expensive.
The guys at the store evidently liked the FHmk3 design, showing interest and asking questions. For instance they asked whether the curve at the back only looked good or if it was for acoustics too. I'll drop by with better drawings at the store in the next days – I think they'll be able to arrange a CNC job for not much money.
Make sure they understand that as simple as the cabinet looks in terms of number of parts, there's several years of calculation and iterative construction behind the drawings, and yes the curve is functional.
like my mind, this space intentionally blank
Old 23rd December 2010, 05:26 PM   #113
kristleifur is offline kristleifur  Iceland
Yep, thanks. I'll be specifying all the pieces down to sub-millimeter accuracy, letting them know it needs to be accurate; I'm giving them precise and clear dimensional drawings, and will be cutting the curve myself. Only the paranoid survive ...
And yes, exactly! - People always ask that - is the curve functional?
Old 23rd December 2010, 05:51 PM   #114
well, sub-millimeter accuracy might be a bit excessive (have you accounted for thickness of glue-line? )
Old 23rd December 2010, 06:22 PM   #115
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
In the words of the Churchill Dog...
Old 2nd January 2011, 10:51 AM   #116
HPH is offline HPH  Viet Nam
Hi all,
I planed to build Frugel-Horn Mk3 for my Alpair 7, please advice me for the drawing, any tips during building process.
Old 2nd January 2011, 03:31 PM   #117
bradhold is offline bradhold  United Kingdom
Hi
I just completed a pair of FH3. A lovely design and a very simple build. I first made an accurate template for the sides from 9mm high quality ply. I used this to draw the shapes for the sides, onto 18mm furniture grade baltic birch ply, which were cut slightly oversize on the bandsaw. I fixed the template to each of the sides with a couple of screws to finish off with a flush trim router bit.
The fronts and internal panels, including angles were all cut by bandsaw.
The hole for the driver was cut by hole saw and then chamfered on the inside with the router.
When gluing up, I started with the front, then bottom, top, back then centre, making sure each panel was perfectly square to the side by using a square. When dry, simply clamp on the other side to complete the sandwich.
Have tried several glues, but like Bison pu Timbermax in cartridge. Very strong bond, easy application, slightly gap filling and easy cleanup when dry.
I am waiting for veneer to arrive. Any advice on driver choice would be welcome. I quite like the look of Alpair 7.
Old 2nd January 2011, 06:35 PM   #118
frugal-phile(tm)
planet10's Avatar
Alpair 7 is very nice.
dave
Old 2nd January 2011, 06:40 PM   #119
Scottmoose's Avatar
Edit: dave beat me to it.
FH3 is designed to be relatively flexible / accept a reasonable range of drivers. Baseline are the Mark Audio CHR70, CHP70, & the CSS branded EL70. The A7 has also been used to good effect. The FE126En also works but as you would expect, this provides a somewhat more damped alignment which is best corner-loaded.
Old 2nd January 2011, 08:49 PM   #120
Decision made. The piggy bank will be broken and a pair of alpair 7 ordered. If the fh3 sound as good as they look, then I suspect my trusty fh1 will be for sale shortly. I will report back when up and running. Thanks for the plans and advice.
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1624 12th June 2018 08:46 PM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 06:16 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
