Frugel-Horn Mk3 Builds & Build Questions
Old 27th November 2015, 03:58 PM   #1141
mightym is offline mightym  United States
mightym's Avatar
Location: Checotah, Okrahoma former home of the Okra Fest
Originally Posted by calrissian View Post
The driver is Alpair 7A. If you could do a 16mm plan that would be awesome. Yeah the Valchromat board is super stiff and good quality, made in Portugal
(In Europe the standard thickness is 8,12,16,19,22mm. )
Post some images of your build, that material looks interesting, and would like to see how it cuts and finishes.....
Old 27th November 2015, 04:50 PM   #1142
chrisb is offline chrisb
yes, indeed
like my mind, this space intentionally blank
Old 29th November 2015, 08:10 PM   #1143
calrissian is offline calrissian  Sweden
Hi! Thank you so much for the plan! And I will keep you updated with pictures.
Old 29th November 2015, 10:58 PM   #1144
a-rone is offline a-rone  United States
Just ordered a Fostex FE126EN driver. I hope to start on my cabinets within the week. What thickness of material would you recommend for this driver?
Old 6th December 2015, 09:11 AM   #1145
Looks like there is some errors in the cut sheet. For example the "top" parts are 172mm in the cut sheet and 171mm in the plan where you see the speaker from the side. The baffle is 898 mm tall in cut sheet and 894mm in the drawing.
Old 6th December 2015, 05:11 PM   #1146
If you're referring to Planet10 cut plans, I 've noticed more than a few minor such discrepancies myself on the literally hundreds of Dave's drawings I've seen and built from over the years.
I always redraw in my own CAD program, as I often construct with different configurations of parts overlay/ insets, add dadoes / rabbets - which will change dimensions of parts drawn with butt joints- and forward some pieces to CNC production. I also always cut slightly larger than drawn and trim to dry fit on the first time build of a design from any source that is not a simple rectangular box.
Old 6th December 2015, 08:50 PM   #1147
Oh i Think im the one who made a mistake this time, the plan is correct, I didn't notice that the angles will have impact on the hight for example.
I managed to take a few crappy pictures with my phone today, next time i will bring my nikon. Still better than nothing.
Old 6th December 2015, 10:28 PM   #1148
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Could well be. What cut sheet, and what plan please so i can check it and correct where needed?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th December 2015, 10:30 AM   #1149
dave
No sorry, my fault,no errors.
Old 7th December 2015, 05:56 PM   #1150
I think Dave is confirming there could still be some errors in dimension snaps - particularly on conversion of drawings for material thicknesses.
Frugel-Horn Mk3 Builds & Build QuestionsHide this!Advertise here!
Frugel-Horn Mk3 planet10 Full Range 1624 12th June 2018 08:46 PM
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 543 4th February 2018 06:16 PM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
