Frugel-Horn Mk3 Builds & Build Questions - Page 10 - diyAudio
Old 16th November 2010, 06:54 PM   #91
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
cut plan for 5x5ft Baltic birch on page 7 of FH-Mk3-betaDoc-251010.pdf[
Cut plans only done for 15mm so far.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th November 2010, 11:08 AM   #92
Some random thoughts:
It seems to me that stuffing the horn is done to A) reduce ripple, B) reduce bass.
Given that the Alpair 7 needs quite a bit of stuffing to reduce the bass, would it make sense to stuff enough to manage ripple, and then use EQ to reduce the bass? The desired positive effect would be to minimize cone excursion - does that make sense? I.e. "overgaining" the bass in the horn, given a certain amount of excursion, and then taking the output down by altering the input signal. Could this help with power handling, excursion, and dynamics?
Old 17th November 2010, 03:12 PM   #93
frugal-phile(tm)
planet10's Avatar
That may well work. Worthy of an experiment.
dave
Old 17th November 2010, 03:58 PM   #94
Precisely! Thanks for the reply. I've had a lot of fun - and some nice results too - with high-quality digital EQ plugins with the Cyburgs Needles. This case should be even more interesting - playing with abundance is a timeless source of fun.
Old 17th November 2010, 05:03 PM   #95
badman is offline badman  United States
Custom Title
badman's Avatar
dave
An RC filter (or even just a first-order highpass) on the speaker could accomplish this- like a reversed BSC circuit. This would have the advantage of providing rumble filtering and giving the amp a nice high load to (not have to) work against in the bass.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 24th November 2010, 01:02 PM   #96
Regarding joints - I built my Needles just by gluing together flat pieces of wood. No reinforcement of joints. Are the Frugel-Horn mark-threes built with more complex joint work?
Old 24th November 2010, 03:45 PM   #97
frugal-phile(tm)
planet10's Avatar
Rarely do we use anything other than butt joints (mostly only on the bamboo ply builds, and that is only to properly take advantage of the end grain).
dave
Old 24th November 2010, 06:38 PM   #98
I wondered about that too. Butt joints work fine. Take a couple scraps and butt joint them with yellow carpenters glue over night. In the morning try breaking them apart ( you won't be able to ). Then consider the glued area of your build.
Old 24th November 2010, 06:54 PM   #99
I know what would happen - the wood breaks before the glue does
Got it. Thanks guys!
Old 24th November 2010, 09:54 PM   #100
chrisb is offline chrisb  Canada
well, of course even today's "miracle" wood adhesives need a pair of decent clean mating surfaces for maximum strength bond
on hiatus
Frugel-Horn Mk3 flat-paks planet10 Planet 10 hifi 522 5th June 2017 04:10 PM
Frugel-Horn Mk3 planet10 Full Range 1583 7th March 2017 10:34 AM
Frugel-Horn Mk3 Auditions planet10 Full Range 24 8th June 2012 07:18 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright ©1999-2017 diyAudio
