Old 27th August 2010, 03:24 AM   #1
norman bates's Avatar
Default Lowther pm6c, is there a freq graph ?
Lowther pm6c, frequency graph anywhere to be found ?
Norman
Old 27th August 2010, 11:46 AM   #2
think I found it.............
2006?02???????????????
??????10?????????? | ?????????
Norman
Old 27th August 2010, 08:07 PM   #3
Bob Brines's Avatar
First, that's not a current Lowther. That's the old whizzer. Second, that plot just doesn't feel right. I've never measured a PM6C, all Lowther's I've seen have a ~10dB hump centered around 8kHz. Perhaps Martin King has a plot he could publish.
FYI, here's a plot of the DX3. I would expect the PM6C to look vaguely similar.
Bob
Old 27th August 2010, 11:12 PM   #4
Thanks bob, that looks like the dx3 graphs I've seen before.
What's with the hole 2.5khz to 4khz ? Is that a mike error reflection thing ?
I havn't seen that on other graphs.
Norman
Old 28th August 2010, 01:54 AM   #5
The one and only
Nelson Pass's Avatar
Here's a PM6C in a large baffle. It looks a lot like Bob's DX3.
(Ignore the curve below 300 Hz)
Old 28th August 2010, 01:53 PM   #6
Bob Brines's Avatar
Probably IS the one you saw before. I've posted this graph a number of times
Oh, that's real as you can see from Nelson's graph. The thing is all of the 8" Lowther's have the same frame and cone. Only the motors are different. So it just stands to reason that the plots would be at least similar.
OT: Note that Nelson's plot is gated while mine is raw and unsmoothed. You have seen demands for unsmoothed plot, but here's the question: Is there any more information is the unsmoothed plot than the gated plot, or are we just looking at artifacts of the room I measured in (anything but anechoic)? Add to that, your ears are going to smooth to something like 1/3 octave, so isn't THAT the plot you would like to see?
Bob
Old 28th August 2010, 06:30 PM   #7
The one and only
The hole is seen on all the PM6's, but is less with the PM6A 8
ohm version and and is slight with the PM6A 16 ohm version.
The PM6A 16 ohm has the flattest response of all the PM6
Lowthers, and is my favorite except for the PM5A
Last edited by Nelson Pass; 28th August 2010 at 06:33 PM. Reason: I forgot the PM5A!
Old 29th August 2010, 09:28 AM   #8
thank you.
Norman
Lowther PM6C Puffin Full Range 23 29th September 2011 08:21 PM
is lowther pm6c worth it ? norman bates Full Range 10 22nd May 2010 04:39 AM
lowther pm6c v dx2 joff Full Range 8 1st December 2008 10:13 PM
FS : Lowther PM6C x2 dhole Swap Meet 2 9th May 2008 08:43 AM
Determining XO point from freq graph zenon Multi-Way 2 3rd November 2006 12:40 AM
Page generated in 0.09157 seconds (76.64% PHP - 23.36% MySQL) with 11 queries
