Old 9th January 2013, 09:51 PM   #931
Bob Brines's Avatar
Originally Posted by chrisb View Post
sorta like airplane monocoque / beam box then?
Or a post-and-beam house!
Bob
Old 9th January 2013, 09:59 PM   #932
xrk971 is offline xrk971  United States
xrk971's Avatar
Speaking of houses, what about speaker cabinets made like a house with framing and drywall gypsum boards?
Old 9th January 2013, 10:06 PM   #933
Speakerholic
Cal Weldon's Avatar
X,
Bead board is the insulation that is made up of little polystyrene beads - it's often called popcorn and is more reasonably priced. The Foam core board we are using is extruded.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 23rd January 2013, 09:48 AM   #934
Just a question , I'm planning on using the fostex FE126 in my frugal horns I built out of (dare I say MDF) . Should the polyfil go all the way up into the woolfelt area or stop right at it. and the Supra baffle .would it help to make it out of BBply or just keep the MDF all the way . Hey I had MDF laying around for a different project and my friend from pa. just got the FH3 flatpacks,so thought I would try it in mdf. thanks. Kevin PS.all 18mm
Old 23rd January 2013, 10:06 AM   #935
Scottmoose's Avatar
Depends on room, amplifier output impedance, wire resistivity and your own preferences. FWIW, with the 126, I'd be inclined just to use it in the first 1/3 of the horn, since the 126 needs all the gain you can get.
Old 23rd January 2013, 12:28 PM   #936
Room 9x13 amp Decware superzen 2.3 wpc output impedance ? 2-6 ohm transformers. I use antcable speaker cable.
Old 24th January 2013, 09:02 PM   #937
One more question in my pursuit. I dont see this Supra baffle being used to much , everybody to lazy to make it ,or is'nt it nessesary?
Old 24th January 2013, 09:11 PM   #938
Scottmoose's Avatar
It isn't needed.
Old 26th January 2013, 10:07 AM   #939
Well thanks Scottmoose, .
Old 26th January 2013, 10:40 AM   #940
Default A tip
I'd like to ad a little 2cent tip here for those of us that use square joints or biscuted joints to join the wood together on these cabinets ,maybe even the rabbited joints after you think you have the 2 pieces of wood glued and joined,run a flashlight, lite of course, down the length of that joint. You may be suprised what you see on the other side. even the best joints I thought were good. Remedy ad glue!!!!!!!!!
The Frugel-Horn Project planet10 Full Range 1158 Yesterday 05:28 PM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright ©1999-2013 diyAudio
