Frugel-Horn Mk3 - Page 93 - diyAudio
Old 9th January 2013, 02:43 PM   #921
Originally Posted by Bob Brines View Post
The major issue in panel sound production is transparency. Wood is a pretty good conductor of sound. The stiffer and harder the wood, the better it conducts sound. This suggest that MDF might really be the better choice for small boxes. I am thinking of even softer materials; polystyrene bead-board or Celotex.
Or perhaps a laminate of a couple materials. Omega Loudspeakers uses an interesting (and I believe proprietary to them) combination of materials, not unlike what you previously used. (Image courtesy of a user on Omega's forum.)
Old 9th January 2013, 05:43 PM   #922
Bob Brines's Avatar
Hmmm. My guess would be low density fiberboard (Celotex?) bonded with an elastic adhesive to 12mm BB. For those who don't know, I used to use 1/4" cement board (HardiBacker) glued to 3/4" MDF with Liquid Nails.
I'm going to try 1/2" bead-board sandwiched between 5mm plywood, using something like PL Premium (urethane) adhesive. Won't be soon, though.
Bob
Old 9th January 2013, 05:51 PM   #923
xrk971 is offline xrk971  United States
xrk971's Avatar
What is bead board?
Old 9th January 2013, 05:56 PM   #924
Scottmoose's Avatar
Bob
Omega? I believe it's 'softwood MDF' laminated to a thin ply layer, and then their 'R compound', which is basically bitumen with some talc added.
Old 9th January 2013, 06:05 PM   #925
Bob Brines's Avatar
Originally Posted by xrk971 View Post
What is bead board?
Shop 1-in x 4-ft x 8-ft Expanded Polystyrene Insulated Sheathing at Lowes.com
Old 9th January 2013, 06:47 PM   #926
chrisb is offline chrisb  Canada
Bob
What type of joinery and adhesives would you anticipate using with core materials of such different properties? PL for the laminating only, or joinery as well?
Love: a constellation of vital phenomena - organization, irritability, movement, growth, reproduction, adaptability
Anthony Marra
Old 9th January 2013, 07:11 PM   #927
Bob Brines's Avatar
I have used PL to glue up complete speakers. Advantage: Long open time. You can put the whole thing together in one pass. Disadvantage: You need at least 24hr before applying any shear to the joints.
I anticipate a solid wood frame around all panels, like a MDF skinned door. That way, all joints are wood to wood.
BTW, I use Titebond I for all of my builds. PL would be for special cases, sort of like Bondo.
Bob
Old 9th January 2013, 07:20 PM   #928
xrk971's Avatar
OK, I am new to these construction material terms. Bead board is polystyrene foam board - nice stuff! I will have to try it. What is PL?
Old 9th January 2013, 07:24 PM   #929
malibujeff's Avatar
Adhesive. Here is a link:
Loctite PL Sealants, Adhesives, Construction Adhesives and Polyurethane Sealants | Loctite Adhesives
Old 9th January 2013, 09:46 PM   #930
sorta like airplane monocoque / beam box then?
Bob
Bondo = Terry Olsen's not so secret Polyester tone sauce
Anthony Marra
The Frugel-Horn Project planet10 Full Range 1225 23rd January 2017 01:15 PM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
Copyright 1999-2017 diyAudio
