Frugel-Horn Mk3
Frugel-Horn Mk3
Old 24th June 2012, 10:06 AM   #851
bullpeters is offline bullpeters  Australia
bullpeters's Avatar
I am buying flat paks tomorrow AM. Having a last minute nervous about alpair 7 vs fe 126n!
To incredible tired from working since 4:30 AM two days ago to pick thru all the thread. I got the Melba's for the flat paks tho!
Driving them from a sixties 20 watt (more like 12 I suspect, clean) valve amp which nevers gets much past 9:30 on the volume controll as it is. I think that the speakers at present are closer to 90 SPL tho.
Please tell me to buy the alpairs! I like what I hear about them, someone just spooked me today, mentioned having 86 SPL speakers and a 200 watt SS amp
basically, will I be able to drive them from valve amp, it's NOT SE? I like the idea of more bass from the Alpairs
Mick
Old 24th June 2012, 11:42 AM   #852
doubtingthomas is offline doubtingthomas  United Kingdom
You might have an issue with SPL.
Old 24th June 2012, 01:34 PM   #853
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
I recommend 10w minimum for Alpair 7, but in smaller rooms people are loving them with less. My bigvalve amp is usually running 20w (triode PP)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th June 2012, 11:29 PM   #854
bullpeters's Avatar
dave
Ok, so I have UL 6bq5's. I think I will take a punt on it. the room is 12 foot wide
Old 25th June 2012, 03:13 PM   #855
chrisb is offline chrisb
A well executed P/P 6BQ5 / EL84 should be quite adequate for Alpair7.3 - my Tubelab SimplePP outperforms a Topping TP30 in every respect (well, except for the power consumption / heat dissipation thing)
not
even
close
like my mind, this space intentionally blank
Old 5th July 2012, 01:21 AM   #856
bullpeters's Avatar
Default Ben From "Sound with style", Good Job!!!
I just received my Frugal Horn flat pack from Ben from "Sound with style" in Melbourne. Unreal! I am well impressed, with the speed of delivery, the way it was packed and the value for money. i am probably capable of cutting them out my self, but for the money, my time is best not spent behind a saw.
Again...Good job!
Old 5th July 2012, 01:44 AM   #857
HPH is offline HPH  Viet Nam
Smile Fe108es or Alpair7.3 in FH mk3
Hi All,
I have a plan to build FH mk3 but wonder which driver Fe108es or Alpair 7.3 should be the best for FH mk3, can you please kindly advice which one I would buy?
Old 5th July 2012, 01:57 AM   #858
bullpeters's Avatar
I went Alpair 7 after what i read. I haven't built/heard them yet tho....
Old 5th July 2012, 01:59 AM   #859
bullpeters's Avatar
Any issues with availability of either in Vietnam?
Old 5th July 2012, 02:15 AM   #860
Thanks for your reply. I am not sure if any FH mk3 available here in Vietnam
Frugel-Horn Mk3Hide this!Advertise here!
The Frugel-Horn Project planet10 Full Range 1225 23rd January 2017 01:15 PM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
