Frugel-Horn Mk3
Frugel-Horn Mk3
Old 18th March 2012, 07:16 PM   #811
nrg2009 is offline nrg2009  United States
How is it possible that the 3 inch driver alpair 7.3 can produce this much bass? I am listining to formula 1 racing and it is just awesome!! The physics behind it must be pretty amazing.
Old 18th March 2012, 07:51 PM   #812
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Frugel-Horn Mk3
Nominal 4" driver.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th March 2012, 02:03 AM   #813
chrisb is offline chrisb
it's not of course, all of us thinking we're hearing something special from this driver are victims of Mark's telepathic abilities
with the number of listeners world wide, how does he manage that?
silly good little bugerz aren't they?
like my mind, this space intentionally blank
Old 25th March 2012, 03:25 AM   #814
zman01 is online now zman01  Bangladesh
Frugel-Horn Mk3
Giving Kodo's Mondo Head a listen on the FH MK3 with CHP-70 Gen1. Getting good sound and BIG sound. To reiterate what last few posts have already stated, it's pretty amazing.
Again kudos to the Scottmoose and other brains behind the design. The synergy with a range of drivers (judging from user comments) makes it very convenient for the DIY community. And not to mention a very elegant, WAF friendly design. I had guests at the house a couple of days back and one of my friends mentioned that besides speakers these are also very nice "home decor".
-Zia
Old 25th March 2012, 08:15 AM   #815
chris661 is offline chris661  United Kingdom
chris661's Avatar
They sound like they go lower than they do. I listened to some larger speakers after some FH3s and the difference in bass extension was obvious.
That's not to say the FH3s are bad: they get a lot out of a small driver, but it is still a small driver, so don't expect full output low down.
Chris
Old 25th March 2012, 02:37 PM   #816
Chris, i agree. They sound very big and bass is very satisfying. I would like to measure them once to convince myself. Also, maybe they sound even better if i don't send the low frequencies to the driver?
Old 25th March 2012, 08:49 PM   #817
chris661's Avatar
Definitely. While the purists may argue about adding complexity, my own experiences have shown me that, for a (relatively) small wide-band driver to shine, something else should do the heavy lifting: small drivers shouldn't be forced to move a lot.
I use a pair of tapped horn subwoofers in my system to handle the bass that the smaller drivers simply can't do. Stopping the bass going to the smaller drivers cleaned the sound up, especially at higher volumes.
Details on my sig.
To test, listen to a track with plenty going on down low through some decent headphones and then the FH3s. Ideally, you'd have a way of quickly switching between the two.
I use Radiohead - In Rainbows - 15 step - YouTube
Just watch out, as the actual bass comes in after around 19sec, so don't turn it up through the speakers until after then. Even so, watch out for pushing them too far: the cones are fragile.
Chris
Old 26th March 2012, 04:41 PM   #818
+1 on Chris661's comment - driven within limits the 7.3 can certainly be safely used unfiltered, but like any welter-weight class FR driver, it benefits substantially from relief of the heavy lifting. I personally prefer XO at line level (either basic passive, or full blown digital with EQ, etc - up to user) - in my particular application this is performed with a HT receiver, so XO on 3 Alpair 7s in the front row is at 110HZ.
Old 26th March 2012, 06:50 PM   #819
chris661's Avatar
Originally Posted by chris661 View Post
Details on my sig.
Just realised I didn't include my sig.
Here it is. Definitely go for line level for low frequency crossovers - the cost of high quality caps gets silly.
My work: www.grimshawaudio.com
Old 8th April 2012, 06:51 AM   #820
Spoonman is offline Spoonman  United States
Spoonman's Avatar
Default Finally finished the pair!
After a few honey do's trumped completing the second FH Mk3 I finally finished it. So impressed with the sound. Once the drivers are well broke in I'm sure it'll be even better. I probably spent ten time longer wet sanding and buffing than I did building them. A long process for sure but worth it.
Frugel-Horn Mk3Hide this!Advertise here!
The Frugel-Horn Project planet10 Full Range 1225 23rd January 2017 01:15 PM
My Frugel-Horn Build italynstylion Full Range 130 22nd June 2010 12:24 AM
