#591 |
Slightly off topic, but....
I demo'd the attached speakers at the Lone Star Audio Fest in May The small speaker is Alpair 7 in a 36" transmission line, the large speaker is Tang Band W8-1772 in a 45L BR. Both have F3 in the 40's. Both produce outstanding bass in the Embassy Suites room. Those who prefer jazz and girl-and-a-guitar generally chose the A7. Those who prefer rock generally chose the TB. Why? The A7 is a bit more lively and has better presence. The TB has more oomph in the upper bass. I prefer the A7 for baroque and classical (in the strict sense). The A7's are now flanking my wide-screen where they replaced Fostex FE166En's in a 40" MLTL. The receiver crosses them to a sub at 120Hz. The A7's are hands down a better, more balanced sound than the 166's. The receiver XO works great for movies with the internal EQ set to EQ the room as flat as possible. For music, I generally run the receiver direct (2-channel, no possessing) and EQ from my computer. Bob |
#592 |
Lovely work as always Bob.
Finish on those looks first rate. I like the combination of the full-length grill & the veneered sides too.
#593 | |
Bob; I found pretty much the same thing when switching from FE167E/FE127E combo to Alpair 7 for the front row 3 (IIRC crossed many 10Hz lower to the LFE channel) . The forward presentation that I don't find at all obtrusive on most music can definitely be a bit overbearing on HT in my smallish (320sq ft) room. How much computer EQ do you find they want for music only?.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#594 |
frugal-phile(tm)
For those interested in deep bass and a bit of kick & a set of frugel-Horns, do keep in mind the optional deflector. Besides providing a slight improvement in bass extention & finese (the choke point in this design makes the gains much smaller than the original), it provides the ideal opportunity for a pair of powered stealth woofers. I'd suggest XO 60-100 Hz with a 1st order PLLXO on the FH3.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#595 |
I did an RTA with the mic at my head position, then EQ'd it flat to ~900Hz. Then I took a few dB's off of the 1-2kHZ peak, but this has to be done very carefully or all of the magic (presence) is lost. Finally, I took 5dB's off 10-15kHz. That top edge bothers me.
I am contemplating another profile with a 5dB notch 6-7kHz to soften sibilance. This would be for pop voice only. I wouldn't want that for instrumentals. I did try a completely flat EQ and it sounded horrible. Flat, lifeless. THIS is the sound that I heard from most every setup at LSAF, including some very expensive speakers. All of these builders/vendors are so shot with a ruler flat FR that they don't realize that that is not what our ears hear. We full-rangers get this peaked, lively response by default since so many (is that better Dave?) of the drivers we use are peaked in the presence range. Bob |
#596 |
If anyone wants to watch a set being CNC machined I took a couple of vids
YouTube - ‪Frugel Horn MK3 flat pack CNC‬‏ YouTube - ‪Frugel Horn MK3 baffles CNC‬‏
Australian Frugel horns and flat pack kits now available at http://www.soundwithstyle.com.au |
#597 | |
What are the "L" angle pieces for?
Intel D410 mITX > Foobar > Musiland 01 USD > Gigawork DAC > Crown XLS1000 > Manzanita Ultra |
#598 |
There was spare space on the board so rather than waste I made them. I had planned to use them as part of the packaging to protect the corners but don't really need them, I suppose they would make good bracing in subs and larger boxes.
#599 |
Bob,
May I ask why you crossed over your A7 at 120hz? Why not lower - say 80 hz - since your A7 can easily go below that? Thanks, UL |
#600 | |
Bob |
| The Frugel-Horn Project | planet10 | Full Range | 1166 | Today 06:46 PM |
| My Frugel-Horn Build | italynstylion | Full Range | 130 | 22nd June 2010 12:24 AM |
